wiring stereo deck!
well, i did a little today and got the 2 rear speakers to work, but damn are they blown to hell, also the speakers in the front were raped to hell, so i have to go buy new speakers tomorrow
but anyways to the point, i noticed i have 2 red/black wires, 2 red/blue wires, and 2 blue wires... is this normal? with the car completely off the 2 red/black wires both get power, and with the ignition on they still both get power, using a testing light.. hmmm so pretty much if i wired up the deck using both the red/black wires the stereo stays on even with the car completely off... i used this Constant 12V+: Red/Black Switched 12V+: Blue Ground: Chassis Illumination: Red/Blue Dimmer: Red/Yellow Antenna Trigger: Black/Red Antenna Left Rear Front Speakers 4" x 6" Doors Left Front (+): Blue/White Left Front (-): Blue/Yellow Right Front (+): Brown Right Front (-): Brown/White Rear Speakers 6 1/2" Rear Deck Left Rear (+): Red Left Rear (-): Green Right Rear (+): Blue Right Rear (-): Pink i tried using the red/black wire and the blue wire and the deck didn't turn on .. hmm anyone know what could be wrong? |
go look up the wiring diagram for the head unit itself. It will explain all. With what you are giving us, you wont get far. what model head unit is it?
![]() Join Date: Jun 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
There should be a yellow wire coming off the deck that goes to your red/black, that is the constant wire. You need to find the ignition power wire which is only powered with the ign switch turned on.
![]() Join Date: Dec 2002
The duplicate constant, illumination, and ignition wires are for an extra plug that goes to the slave deck, either a cassette, single CD, 3CD player, or the 6disc indash. All Nissan cars have the extra plug behind the radio, usually taped back in the harness. Leave them loose and insulated or tie them together with their counterparts, doesn't matter.
![]() Join Date: Apr 2004
I don't think even you are that omniscent ![]() |
All the wire colors match up the S13 chassis, Nissan mixes and matches colors per vehicle so I'd have to say it's not anything else.
