#34 | |
![]() Join Date: Jul 2005
Your bypass valve (blow-off) was causing the idle drop / rich stall condition you had. That is why tightening it seemed to help. You could have further diagnosed the issue by tape'ing the damn thing shut with some regular duct tape and go for a drive to verify. Shady mechanics that notice you know nothing about cars will tell you whatever you want to hear and charge your ignorance. |
#35 |
Tbh i really dont know. I only just got the car for like a month. Like i said i have hks camshafts but apparently they said one of the valves or lifter is worn out and had a big gap or something like that which caused some mix up
#36 | |
So lets talk about this as well. The factory intake rubber (and all similar length inlet tubes, like the greddy) is designed with the factory bypass valve in mind, meaning that, at idle, and during off-throttle conditions, the bypass is leaking air back to the rubber intake tube to prevent this exact problem. When you install an aftermarket Bypass, such as a HKS SSQV, or any bypass that holds shut at idle, the air will flow backwards through the turbocharger (instead of through the bypass) at idle and the maf sensor will see that and the engine will run rich when you lift from the throttle. You can fix with an extended/bendy inlet tube, or running an open bypass at idle (such as a recirculated greddy type-S) |
#37 |
Its complete nonsense. You cant even see the valves or lifters without taking apart the engine. And if a valve was bent or ruined, A: the car wouldn't run well B: compression will be lower (a compression test is free and easy to do) C: if they took apart the engine and found a bent valve, they should return it to you for proof. Never take anyone's word. Also, a real shop performs a compression test before touching anything, or making any bold claim about a valve/lifter. Where are your compression test results?
#39 | |
You can NOT just look under a valvecover and see a bent valve. You can't really see anything except whether the rockers are all intact and if the lobes look good. Also... "Found It" that found WHAT? You still havnt been specific with what exactly "they found". Nobody, even you, has any clue what "they found" because they probably didnt find anything. You are getting scammed, is my diagnosis, based on the information you have provided. |
#41 | |||
![]() Join Date: Aug 2011
Also if the maps you have are set for 104 octane, you'd have melted your pistons or made holes in them. High octane = more timing = tons of detonation and swift engine death with regular octane. Go away from that shop. Quote:
Can you name that shop, so other people DON'T end up there ? |
#42 | |
#43 | |
Meaning you have either a nisTUNE, or a nismoTRONIC, but neither are a nismo ECU ... Do as you want, just dont come crying. mapped at 104 octane, worn AAC so "they set it at low boost"... you are either a genius troll or a genuine idiot. I really can't tell. |
#44 | |
| idle |
