#246 |
Looks great!!
Why is the drivers strut tower a different color? Sorry I'm new to the thread.
'95 240 | @SleepySteve72 |
#247 |
![]() Join Date: Sep 2011
I just recently got rid of the power steering resivoir mounts and I also got rid of the hood prop to run hood dampers. Ill sand the primer and repaint those parts of the engine bay after tuning.
#253 |
So in my quest to change a few things for rhis summer ive been making progress on the interior
I have a whole list of stuff on the way. Steering wheel, hub, gauges. Recently I painted the plates I made for my core support. And I wired and painted my kouki cluster. Sitting in the U.P.Garage theater watching option video and wiring my cluster. Ive also been cleaning up the wiring inside the car and prepping for all the defi gauges I ordered. Moved the fuse box from the dumb spot I originally put it in. Ill have pics of its final spot when the dash is back in. I also wired of digital climate control and its going in. Best skyline upgrade: C's short shifter |
#258 |
![]() Join Date: Nov 2009
when you get a chance, can you take some high res pictures of your car
I really need a new background. my screen is 2560x1440. the bigger the better ![]() Thanks if you can. |
#262 |
herrro momo... So you can't run the NRG Slim hub with the NRG Slim quick release. So I made a spacer to offset the recessed portion of the quick release. The spacer is 5/8". With the spacer the slim hub and slim quick release is still 1" shorter then a slim hub with a normal quick release. Pretty pleased.
#265 |
Looks great, good job.
#270 |
I like slim quick release. It works just fine. The downside is you cant run it with a slim hub. Kinda defeats the purpose. I just made a spacer. Not sure where that puts it compared to running a regular hub but I do know the wheel is still an inch further away then a slim hub and normal quick release.
As for Led's in my climate control yes they were plug and play. The neo 3's is what works: NEOx LED Bulb - Instrument Panel LED | Instrument Cluster and Gauge | LED Car Bulbs | Super Bright LEDs |
