Old 11-06-2010, 11:48 PM   #181
Fries
Fries's Avatar
Fries is close to perfectionFries is close to perfectionFries is close to perfectionFries is close to perfectionFries is close to perfectionFries is close to perfectionFries is close to perfectionFries is close to perfectionFries is close to perfectionFries is close to perfectionFries is close to perfection
bumpity bump mr. hpipro. [p.s. good thing I didnt waste my time tucking on my ka24, the motor I had ended up being garbage, now researching how to eliminate all the bullshit on an sr20].
Fries is offline   Reply With Quote
Old 11-07-2010, 12:24 AM   #182
hpipro4
hpipro4's Avatar
Trader Rating: (71)
hpipro4 is an unknown quantity at this point
Feedback Score: 71 reviews
shouldnt be a headache if your just doing your engine harness. unless your redoing your fuse/relay boxes, like how i did mine thats went things get complicated well not really unless you know what your doing!
goodluck bud
hpipro4 is offline   Reply With Quote
Old 11-07-2010, 12:29 AM   #183
Fries
Fries's Avatar
I want to do a full over like you did, nothing a little more research wont fix. Get me learn'd real gud. Howd that aero come along?
Old 11-10-2010, 01:29 PM   #184
T chop
T chop will become famous soon enoughT chop will become famous soon enoughT chop will become famous soon enoughT chop will become famous soon enoughT chop will become famous soon enough
I have an S13, Silvia headlights, no heater etc.
I can get rid of both relay boxes,both OEM fuse panels and replace it with about a 12-18 Fuse box? How many relays would I need?
T chop is offline   Reply With Quote
Old 11-10-2010, 08:55 PM   #185
GSXRJJordan
GSXRJJordan's Avatar
I've been doing a lot of custom chassis harnesses lately, but have come back to doing more OEM-style tuck-and-loom jobs on high-end cars that want to retain all their factory systems. By far the hardest system to keep is HVAC, just because there are so many different units (blower motor, mix door, etc, etc) and control is very decentralized... you end up not cutting anything out and having to re-wire the whole thing into your new chassis harness.
With Silvia headlights you lose the headlight up/down nonsense and the S13 doesn't have a headlight relay (power for the headlights goes through the switch). Losing HVAC saves a ton of headache. You'll still want an ignition relay to power your coil/coilpacks and ECU/sensors, fan relay(s) to kick on your electric fan(s), a fuel pump relay to handle the fuel pump, and your ignition switch with a big fuse on it to handle accessories. This is all assuming the most basic harness, and it gets complicated very quickly.
Like I tell everyone, no matter what car - if you read the FSM and can't instantly be comfortable with the wiring schematics, you will have a very difficult time at best, and create a nightmare that will never work at worst.
Old 11-11-2010, 12:09 PM   #186
T chop
Ok that sounds not to bad, I was in the process of relocating my panels to the glove box but what I did was cut the harness, pull it out of the engine bay, loop it around the other way and solder it back together, but now it just looks fucked and it would probably be easier for me to just start over.
Old 11-11-2010, 01:04 PM   #187
GSXRJJordan
Hope you marked everything, because I can think of 6 or 8 wires that are exactly the same size (or vary by one size) and have the same colors, in the same area. I've seen quite a few hacked chassis harnesses that don't work after something like that, and we have to start over.
Old 11-11-2010, 01:18 PM   #188
hpipro4
hpipro4's Avatar
Trader Rating: (71)
agreed!!! sharpie n tape is ur buddy in wire tucking.
Old 12-03-2010, 12:12 AM   #189
T chop
Ya I numbered them, but anyway I'm going to start 100% fresh. Engine harness is untouched and will remain untouched until everything is sorted out and I have my final setup as far as intake mani etc.
What do you guys think of using this setup?
14 CIRCUIT FUSE PANEL W/FLASHERS/HORN RELAY on eBay.ca (item 110448768946 end time 16-Dec-10 09:54:24 EST)
TR-1400 Replacement Fuse Block
The TR-1400 Replacement Fuse Block kit allows for just the fuse panel in your vehicle to be replaced. The TR-1400 also includes many of the great features that our complete wiring kits have. It includes:
  • 14 Pre-wired and Fused Circuits
  • High / Low Beam
  • Parking Lights
  • Gauge Power / Interior / Dash Lights
  • Turn Signal / Hazard Lights
  • Brake Lights
  • Horn / Cooling Fan Circuit
  • Ignition/Coil/Distributor
  • Starter Circuit
  • Charging / Alternator Circuit
  • Fuel Pump
  • Radio / Accessory (Constant Hot)
  • Radio / Accessory (Ignition Hot)
  • AC/Heat Power & Fan
  • Pre-wired Neutral safety
  • 14 ATC Fuses
  • Pre-wired Flasher Unit
  • Pre-wired Hazard Unit
  • Pre-wired Horn Relay
  • Compact easy to hide design
  • Pre-wired turn signal circuit
  • Connections in block are crimped and hand soldered
  • Aluminum Base
  • Brushed Aluminum Fuse Cover
  • Wires labeled by circuit & colored to match GM factory wiring codes
  • Instruction Booklet"
Old 12-03-2010, 03:31 AM   #190
GSXRJJordan
The generic wiring harness/fuse block setups that I've seen don't do the important stuff very well ~ you're left with one ignition relay (usually fused at 30A) to handle everything that's ignition-switched. Not ideal. Depending on the chassis, you also have problems with lights/blinkers/etc.
Aside from that, they handle the little stuff well, and usually are a compact package.
Old 12-03-2010, 12:59 PM   #191
T chop
What would you suggest then with out spending too much money? I want to be able to keep it under $300 for everything, I guess I could spend a little more for a good setup though.
Old 01-05-2011, 12:44 AM   #192
hpipro4
hpipro4's Avatar
Trader Rating: (71)
thought id update my build......
scored a ka-t stuff locally and decided to take out dash again and re-wire/relocate where my gauges will go...decided that im going to ditch center vent and creat my own triple gauge pod using fiberglass stay tuned...
also wired in an viper 5901 remote start system...lovin it!
ditched the center and taped it with foil tape...y?? i dunno i felt like it..haha
moved some of the relays to the top so their not showing underneath glovebox.
i g0t very creative and modded my toplite that i never use and manage to fit my greddy mss(use as fan controller) in there w/o doing anything to much just using dremel w/cut off wheels and viola!!!!!i think it turn out perdy cool. wat ya think?
Old 01-05-2011, 01:28 AM   #193
Wake
Wake's Avatar
You sir, are my hero.
My new plan is to find a dash/chassis/engine room harness out of a 91+ with power options and completely rewire my piggy as a chuki when I do my dohc swap.
Then after i build a custom harness for a track car ill build a new one for my DD.
S.P.P.S. Member #00
**CoUpe LOve** Member #00
Old 01-05-2011, 01:51 AM   #194
GSXRJJordan
That's supposed to be a tucked dash harness? I mean, I get that you de-loomed it and zip tied it, and I assume you cut some un-needed wiring out, but damn.
That still looks like a whole pile of stuff I don't want/need under a dash.
I'd also look into relay holders that can be mounted to a plate (or that heater box you still have) rather than having all your relays free-hanging and moving.
This is a custom fusebox/relay setup that I did for a SR20'd Datsun 510, retained all OEM functionality (with OEM switches, ugh) in addition to an alarm and 9 gauges.
Another one, you can see the three sections of loom that converge to cross the dash (engine harness, front chassis harness, rear chassis harness) and the back of the bulkhead connectors here
Are you still using the SMJ and driver's side interior fusebox?
Old 01-05-2011, 01:52 AM   #195
hpipro4
hpipro4's Avatar
Trader Rating: (71)
haha im no hero...lol
i am too looking for a black dash.....been hitting my local junkyards but their all junks lol...maybe ill just paint my brown dash instead.
yea i didnt bother sleeving the wires since their underneath the dash...like anyones gonna be peeking thru...lol
works just fine i dont feel like changing em again but thats neat idea tho
Old 01-05-2011, 02:22 AM   #196
Wake
Wake's Avatar
I have a badly cracked black dash and a HUD dash with a tiny crack on the hood above the gauge cluster. dunno if that does you any good but if you plan on flocking or fiberglassing or something over a dash I got you covered.
Hey jordan you still any kind of write up or info on the wiring of that 510? I will be doing the same thin on my buddies dime pretty soon.
S.P.P.S. Member #00
Old 01-05-2011, 02:48 AM   #197
GSXRJJordan
1) Remove all 510 wiring, clip off 2" pigtails for tail light wiring.
2) Pen and paper the new electrical system, choose circuits, fuses, then wire size
3) Run wire, solder into pigtails as close as possible to connector
4) Loom everything. Loom some more. Then do some more looming.
5) Connect crappy 1960's switches to your awesome new harness, making it only slightly more reliable than it was
6) Test
7) /wrists if anything doesn't work, since you've already loomed it all (my stuff always works)
Old 02-10-2011, 10:38 PM   #198
s13coupej
s13coupej is on a distinguished road
What wires u had to extend as for starter and alternator
s13coupej is offline   Reply With Quote
Old 02-10-2011, 11:14 PM   #199
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
keep the brown, i like it.
idahotuner is offline   Reply With Quote
Old 02-12-2011, 05:42 PM   #200
GSXRJJordan
I generally run a 100amp inline fuse in a marine fuse holder between the alternator and starter on a street car with 4ga Mil-spec wire, then 4ga back to the battery with a large fuse near the battery to protect the wire running through the car (200A-300A). Then you just loop the alternator exciter wire up to the alternator charge post and you're set.
Old 02-24-2011, 02:02 PM   #201
Likethunda
Likethunda's Avatar
Likethunda is an unknown quantity at this point
at first i thought "this dude is nuts"..... but as i see your Results..im LIke "Wow".... Mad Props..... whish i had the patients for wiring.... well i guess i might since im building up my hatch right now.. =).....
Likethunda is offline   Reply With Quote
Old 05-15-2011, 12:32 AM   #202
hpipro4
hpipro4's Avatar
Trader Rating: (71)
thought id update my build....just recently finished my ka-t here it is....
Old 05-15-2011, 01:46 AM   #203
usdm180sx
usdm180sx's Avatar
wait what kind of brown are you?
Im kinda feeling the brown, watch I guarantee in a year or two everyone is gonna be jocking brown and blue interior.
yeah im about to do a 5sp dohc swap and im thinking of doing a mild tuck and deleting/filling/painting some shit.
My engine bay is getting painted at least if nothing else.
I loves teh brown interior. And I'm Pinoy too Nice job on the wire tuck!
-Norm!
Old 05-15-2011, 09:31 PM   #204
hpipro4
hpipro4's Avatar
Trader Rating: (71)
interior is all blk now!!!haha
glad to see other pinoys here...
Old 05-22-2011, 12:22 PM   #205
punn303
punn303's Avatar
Trader Rating: (82)
punn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymorepunn303 is not welcome here anymore
Feedback Score: 82 reviews
looks good
punn303 is offline   Reply With Quote
Old 07-05-2011, 09:02 AM   #206
EjMalernee
EjMalernee's Avatar
EjMalernee is an unknown quantity at this point
Nice job man. This thread and the info in it has helped me so much. I was at a real lost when I started my tuck. Now I understand a lot more.
EjMalernee is offline   Reply With Quote
Old 07-05-2011, 09:14 AM   #207
hpipro4
hpipro4's Avatar
Trader Rating: (71)
thnx! glad it helped you bro.
Old 07-05-2011, 09:49 AM   #208
future
future's Avatar
Trader Rating: (42)
Feedback Score: 42 reviews
Power numbers?
Old 07-05-2011, 09:35 PM   #209
hpipro4
hpipro4's Avatar
Trader Rating: (71)
Originally Posted by future View Post
Power numbers?
still havent gone to a dynoshop yet......
Old 07-10-2011, 11:32 AM   #210
Bubba
Bubba's Avatar
Bubba is making his/her stupidity well-knownBubba is making his/her stupidity well-knownBubba is making his/her stupidity well-knownBubba is making his/her stupidity well-knownBubba is making his/her stupidity well-known
Damnit man. This is probably one of the best threads I've come across so far.
Thanks for all of the helpful info, and thank you Jordan for answering one of my biggest questions.
Harnesses are de-loomed now and I'm laminating my diagrams.
Good at wrenching, terrible at electrical. Lord help me... HAHAHA
Bubba is offline   Reply With Quote
