1997 240sx se rb25det
SOLD!
1997 Nissan 240sx SE Clean California Title, registered (Car is located in San Diego, California) Original for sale thread can be found here-#/f/showthread.php?t=637652 Please check out the old thread imgur album. There are 181 images of the car, items, paperwork, etc. https://imgur.com/a/MzADb The most recent photos of the car https://imgur.com/a/hlqN5Hc This car came factory with an automatic transmission, power windows, power locks, power mirrors & no sunroof. I have owned the car since 2009, originally I wanted a fun daily so I converted it to a manual transmission and swapped in a built KA24DET. I drove that for a while, had a throttle body screw come loose and blow the motor up. My intention was to re-build a stout rb25det and possibly drag race it on the weekends. I am now a proud father of two girls and and my priorities have shifted hence the reason for selling. The car was posted for sale 4 years ago as a project, but all of the work has been finished and the car is now a complete running daily driver. Overall the car is in excellent condition and I am in no rush to sell it. Lowball offers will be ignored. Carfax report (says 6 owners but only 4 total, 2 are just title updates) http://clicks.email.carfax.com/ls/cl...G2wY9H5V0Q7b5i Feel free to contact me via this listing, phone/text (619)739-3296 or email at [email protected] SOLD Motor/Drivetrain: -RB25DET Series 1 motor w/ RB25 5 speed transmission -Machine shop work (Vat clean, block report, crank report, polish, align bore, deck inline, bore and hone, plugs, balance rotating assembly, fit pin + mount piston, machine and install pump drive (Raw Brokerage Crank Collar), resurface and file fit rings) All work done by Car Parts Machine in El Paso TX. -All new OEM Gaskets -Cometic head gasket -Cometic exhaust gasket -Nissan N1 oil pump -Nissan N1 water pump -ACL bearings -CP Pistons -Manley Rods -ARP head studs -ARP main studs -Tomei Poncams 256/256 -Tomei adjustable exhaust cam gear -Stock turbo and manifold -Greddy intake manifold with Q45 throttle body -ACT 350z 350mm clutch -Exedy billet chromoly flywheel -Zerolift motor mounts/trans mount/ 1 piece steel driveshaft -Megan racing engine and transmission mounts -J30 differential -Stainless BRM exhaust w/ Magnaflow resonator/muffler -CXRacing turbo elbow -Redline 75w90 gear oil in the diff and MT-90 in the transmission -Mobil1 10w40 engine oil -Carbon fiber front cover (not mounted) and coil pack cover (mounted) -HKS SSQV BOV -ISIS short throw shifter -N60 MAF -S15 power steering pump Fuel: -AEM 50-1200 E85 compatible in tank fuel pump -Nismo adjustable fuel pressure regulator - -8 AN Braided Fuel Hose/Feed - -6 AN Braided Fuel Hose/Return -Bulk head fittings installed at the fuel tank cap -Russell Competition 40 Micron Inline fuel filter installed on feed line -Runs on 91 octane Electrical: -Battery relocated to the trunk with the main power running through the interior of the car -Custom battery box with mounted fused electrical disconnect -Prosport oil pressure gauge -Autometer boost gauge Cooling: -Koyo aluminum radiator -Front mount intercooler w/piping -Arizona Iced Tea over flow tank -Aluminum reservoir for power steering fluid, AN fittings installed on tank and on steering rack, nylon black braided lines connect everything -Has all of the AC components including the RB25 a/c pump. I have all the stock s14 compressor lines but they need to be modified to fit. Everything is in a tote and not mounted except the condenser. Suspension: -KYB AGX springs and struts -SPL aluminum subframe collars Wheels : -350z wheels (x4) -Continental Extreme Contact 225/45/17 tires. Still have lots of tread left Interior : -95 240sx seats front and rear -Kenwood KDC138 Headunit -Nardi Sport Rally Deep Corn 330mm (black with red stitching) -NRG short hub black -NRG quick release 2.5 black/black -Blue bubble shift knob Exterior: -Street Faction front bash bar -Kouki SE lip Bad: -Transmission is making a whining noise when clutch is pressed in. Throwout bearing was replaced and all contact points were greased and the noise remains so I am guessing the transmission needs a bearing or something. -Headlights need adjusting -Passenger side door is missing the door swing stop -Struts squeak and need to be replaced or upgrade to coilovers Not included in sale but can be added: -PTE 1600cc injectors x6 -Weld Prostar 15x8 (x2) w/ Mickey Thompson ET Streets 26x10.5 Last edited by DUDEIDONTHAVEA240; 06-26-2021 at 02:35 PM.. Reason: Sold. |
