S13 Kouki Tail Lights, Odyssey mini battery, Nismo parts, and lots of stock S13 parts
S13 Kouki tail lights - $400 SOLD
http://i1144.photobucket.com/albums/...j/DSCN0669.jpg http://i1144.photobucket.com/albums/...j/DSCN0671.jpg Nismo slave cylinder (0 miles, but it was put on a car and had fluid run through it) - $180 3" universal high flow cat + two weld on 2-bolts flanges - $140 Nismo clutch pivot - $40 SOLD http://i1144.photobucket.com/albums/...j/DSCN0716.jpg S13 SR20DET rocker arm stoppers - $30 Nismo oil filler cap - $90 SR20DET Nissan OEM radiator hose set - $40 SR20DET Greddy oil filter sandwich plate + pressure sending unit - $40 SOLD http://i1144.photobucket.com/albums/...j/DSCN0721.jpg Nissan OEM SR20DET S13 water pump - $50 SOLD http://i1144.photobucket.com/albums/...j/DSCN0676.jpg Odyssey mini 11.5lb battery - $120 S13 SR20DET transmission spacer dust shield - $20 SOLD http://i1144.photobucket.com/albums/...j/DSCN0728.jpg 91-94 S13 clear bumper lights - $20 SOLD http://i1144.photobucket.com/albums/...j/DSCN0705.jpg S13 front strut tower bar - $40 Solid transmission mount - $40 S13 lug nut covers (3 perfect, 2 missing 1 clip each) - $5 each for perfect, $3 each for 1 clip missing SOLD http://i1144.photobucket.com/albums/...j/DSCN0681.jpg S13 hatchback hatch carpet - $40 each metal part that attaches the carpet to the seat $5 RJS racing harness. Very sturdy construction, but kind of rough condition (nothing that compromises their integrity, just looks) - $10 What's left of an S13 SR20DET gasket set. Includes, intake manifold gaskets, head gasket, crush washers for turbo lines, all turbo related gaskets, among some others - $40 SOLD http://i1144.photobucket.com/albums/...j/DSCN0687.jpg S13 driver's side rear interior piece - $15 S13 passenger side door panel (small hole below left of speaker screen, otherwise great condition) - $40 S13 power steering reservoirs (one RHD, one LHD) - $10 each (LHD sold, RHD still available, but does not have the cap until I can find one) S13 front seats, the passenger is in excellent condition, the driver's has wear in the usual spot, but is in great condition as far as used S13 front seats go; there is no foam visible - $25 each Weld ProStar 15X10 with Mickey Thompson 275/60/15s mounted. Never used - $250 SOLD http://i1144.photobucket.com/albums/...j/DSCN0696.jpg S13 fender liners, excellent condition - $15 each also have most of the hardware SOLD Vent thing for S13 hatchback - $3 KA24E distributor - $20 Battery tie down - $3 SOLD S13 SR20DET stock head shield - $15 Spark plug wire holder - $3 S13 drivers side door, complete. Comes with window, window regulator, door panel, speaker, all wiring, everything. Excellent condition. - $150 Complete headlight assembly minus the headlight. All brackets, motor, headlight cover, and also the horn and horn pigtail KN13 brand new splash guards. Rears will mount perfect to an S13 on existing sheet metal, just have to make new holes for the screws. The fronts will require a tab to be welded on to the fender or a bracket made for the bottom mount point - $40 SOLD http://i1144.photobucket.com/albums/...j/DSCN0639.jpg http://i1144.photobucket.com/albums/...j/DSCN0640.jpg S13 glovebox, one mount missing the pin, and there is no handle - $5 S13 hatchback driver's side hatch interior piece - $5 S13 hatchback rear hatch interior piece - $15 S13 hood prop - $10 S13 door sill - $10 S13 hatchback driver's tail light (has crack) - $5 S13 hatchback center tail light (has chunk missing, see bottom right in picture) - $5 S13 headlight assemblies, complete with motors and headlight pigtails - $25 for the passenger, driver's side is sold S13 head light motors - $10 each SOLD S13 head light covers (2 passenger's only, driver's is sold) - $10 each S13 head light surround trim finisher shrouds (SEO ). 2x passenger's (they are upside down in the picture) - $10 eachS13 popup head lamp - $5 S13 head light metal housings - $5 each S13 ECU kick panel - $10 SOLD S13 automatic center console bezel - $10 Last edited by brickerj; 05-14-2013 at 07:22 PM.. |
Random S13 seat belt pieces - $5 for all
S13 SR20DET stock intake manifold - $10 S13 SR20DET water neck (has hold tapped for water temperature sensor - $10 S13 SR20DET water hoses - $10 S13 SR20DET IACV - $40 S13 SR20DET temperature sensor housing + sensors - $20 S13 hatch back hatch release and lock cylinder (sorry, no key) - $5 S13 upper steering column cover - $10 S13 below dash panel - $10 SOLD S13 distributor cover - $2 SOLD S13 fuse panel cover - $2 S13 driver's side dash buttons (all come with harness side pigtails) - $5 each (cruise control buttons sold) S13 SR20DET IACV - $40 SOLD Door pillar covers - $10 each Driver's side power window buttons - $10 Chrome lugnuts - $10/set S13 defrost button, O/D light, hazards button (all come with harness side pigtails cut) - $5 each S13 climate control with harness side pig tail - $10 SOLD random other interior bits - $1 each S13 sun visors - $10 each (only one driver's side left; others sold) S13 light stalk, comes with harness side pig tail - $10 SOLD S13 wiper stalk, comes with harness side pig tail - $10 other picture interior bits - $2 each Washer fluid reservoir and pumps - $10 5Zigen FN01RC center caps - $5 SOLD http://i1144.photobucket.com/albums/...j/DSCN0707.jpg S13 front hood seal - $5 S13 89-90 bumper lights turn signals - $15 S13 wind shield wiper arms (2 need repainted) - $10 S13 tail light trim pieces - $10 each SOLD http://i1144.photobucket.com/albums/...j/DSCN0700.jpg S13 fuel pumps (2 come with harness side pig tails cut) - $20 each Anything pictured - $1 each S13 top bumper support brackets - $10 each S13 side bumper support bracket - $5 S13 rear CV joint rebuild kit - $10 SOLD http://i1144.photobucket.com/albums/...j/DSCN0718.jpg S13 shifter seal - $5 SOLD http://i1144.photobucket.com/albums/...j/DSCN0720.jpg S13 rear quarter panel corner light - $5 Front lip (or wing???) for unknown Nissan vehicle (will work as front lip on S13 with minor modification - $15 S13 SR20DET stock SMIC - $10 OEM sun roof wind deflectors, one is for a 96-00 Sentra and a 96-99 200sx, the other I'm not sure, but it looks identical - $20 each Early 90's Nissan carpet (not sure what vehicles, but I think Pathfinder and Quest) - $10 each 90/91 Nissan Quest recall kit - $40 Early 90's Pathfinder (or Xterra?) head light grills - $10 Last edited by brickerj; 06-30-2013 at 07:54 PM.. |
#11 | ||||
Replied to you. Quote:
They use the stock hardware. 35 $ shipped. |
Maybe? I don't know, but people use them in cars to save weight and engine bay space. It works fine, it just lost juice after a few cranks for me since I'm running an Aeromotive A1000 which pulls a lot of power.
The sun visors are for an S13. I'm not sure what the sunroof deflectors are for. Either an Xterra or a Pathfinder. And I'm not sure about fitment on a 240 because mine does not have a sunroof. |
#19 |
One of the sunroof visors is for a 96-00 Sentra or 96-99 200sx. I'm still not sure about the other one, but it looks identical, so it's probably the same. Still not sure about the fitment on a 240sx because mine does not have a sunroof.
#21 |
