t28 turbo how to adjust the actuator or wastegate
hey guy i just bought a t28 turbo from o e of the member here how do i adjust it or do i need to change it in order for me to adjust it??? thanks in advance
Sent from my SM-N900T using Tapatalk |
If the actuator rod is threaded you can tighten it (pull the flapper closed tighter) but I don't think the factory turbos had that. Any aftermarket garret with internal gate usually comes with an adjustable actuator.
S13- 2jz, 370z 6spd, PT6262 Nissan Master/GT-R Technician |
![]() Join Date: Jan 2010
well which way adds boost on a threaded actuator? tighter or looser??
Basically If its adjustable it'll have a small lock nut on it, break that free and turn the WG rod clockwise (prob grab it with pliers) , making it shorten and tighter... End result boost goes up and shit gets real
