Old 03-26-2009, 01:01 AM   #1
kevmeistah21
kevmeistah21's Avatar
Trader Rating: (68)
kevmeistah21 is an unknown quantity at this point
Feedback Score: 68 reviews
Send a message via AIM to kevmeistah21
signal lights/emergency lights DON'T WORK!
I checked my signal light fuse already and it's perfectly fine. What could it be?
kevmeistah21 is offline   Reply With Quote
Old 03-26-2009, 01:04 AM   #2
Opie
Opie is an unknown quantity at this point
hazard switch
Opie is offline   Reply With Quote
Old 03-26-2009, 01:12 AM   #3
kevmeistah21
Trader Rating: (68)
the fuse? i'll go check it right now.. it's a 1991 coupe by the way.
Old 03-26-2009, 01:18 AM   #4
kevmeistah21
Trader Rating: (68)
ok i checked the hazard fuse and it was out, replaced it and now my hazards work but my signal lights still don't work.. PLUS i could turn on my car without pressing the clutch, wtf i didn't know that? is that normal...? i have a 1991 coupe with a blacktop sr20..
Old 03-26-2009, 01:20 AM   #5
Opie
If the car was automatic before, then yeah thats probably the reason you can start the car without the clutch, if the hazards work now and not the signal lights, I would imagine the issue is in the combination switch on the steering column.
Old 03-26-2009, 01:24 AM   #6
kevmeistah21
Trader Rating: (68)
ehh i removed the plastic things that are around the steering column like last week maybe fucked up some wires? i'll check it out tomorrow.
Old 03-26-2009, 01:27 AM   #7
Opie
it could be the wires, or it could just be an old switch thats gone bad, call a friend with an S13 and throw his/her switch on your car just to test it.
Old 03-26-2009, 01:33 AM   #8
kevmeistah21
Trader Rating: (68)
i have no friends locally that has an s chassis. I could go to the junkyard and pick one up.. thanks for the quick/helpful response!
Old 03-26-2009, 04:33 AM   #9
discosteak
discosteak's Avatar
discosteak is an unknown quantity at this point
you probably forgot to plug something back in
discosteak is offline   Reply With Quote
Old 03-26-2009, 07:46 AM   #10
projectRDM
projectRDM's Avatar
Flasher, hazard switch, or combination switch could each or all be bad. Download FSM, perform regular diagnosis per instruction.
FORMERLY R240NA
Old 03-26-2009, 06:33 PM   #11
kevmeistah21
Trader Rating: (68)
soo i found out and fixed the problem. The previous owner of the car hardwired the lights pretty wierd and one of my plugs was disconnected from my left side corner light which caused the hazards and turn signals fuse to blow. Thank you for your help!
