#331 |
Bandwagon.
i thought going with a s13.4 you wouldnt need a catch can?
#333 | |
![]() Join Date: Sep 2005
Changing the valve cover design isn't going to eliminate blow-by!
I think people don't understand the "crankcase vent", It's routed to the valve cover because the valve cover has provisions for evacuation. On the oem S14 valve cover, the oil that may come up from the crank case, will not make it to the intake like in the s13 config. The valve cover acts like and oil air separator, in the s14 and s13.4 configs. So adding a catch can just insures there is no oil in the intake. Quote:
#334 |
![]() Join Date: Jan 2005
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
The best solutiion is to run a line from the valve cover to the exhaust with a check valve or pcv valve...honda guys have been doing this for years....just my $.02
Parting out SR build.... |
#336 | |
![]() Join Date: Oct 2004
Turn and Burn!
#337 | |
Sorry for such the long quote everyone. This is my first post and I am here because I found this information from fellow service members on Zeroyon. I am excited to have a clue where some of my problems are coming from and it seems it is the restrictors. Now I see the picture on the inlet that shows the restrictor and I also have seen Ben's diagrams on sr20 forum. Now I am baffled cause I am trying to find the second restrictor he mentions in this post in the WOT section. I can not find any information on it in his diagrams or on the service manual, and yes I have the JAP 180sx service manual. Here is a shot of the breakdown of that area. I want to know if there is a restrictor in there and if I can simply just add it into my line from the crankcase bleed. Last edited by quickdiversion; 05-22-2013 at 12:08 PM.. |
#338 |
So just to make sure I understand. I have a s13 and if I go off the T on the valve cover on the turbo side to a catch can and then off the catch can to intake tube of the turbo this will relieve the pressure from the head/crank to stop blow by??? Is this the just of it.
#340 | |
#341 | |
My SR20VET |
#343 |
Yes, there are other ways to do it though.
Search this forum for catch can setups. You should find that there are a lot of threads pertaining to this setup and will answer your questions.
My SR20VET |
#344 |
![]() Join Date: Jul 2011
I run it like this and have never had a problem. Still need to refine my tune but I think I'm around 300 whp or so, and this is my daily.
It's still obviously a work in progress as far as final routing of plumbing, but this catch can plumbing setup has been setup on the car for a few months now with no oil collection in the can.
#345 | |
The negative pressure, allows the piston and rings to move freely reducing pinging, slapping and knock which can be heard and felt at idle speed with a misconfigured catch can setup. (Plugged, capped or no vacuum setup) You could simply try this by capping off the hose that would be sucking the air out of the valve cover, try it! If your rings aren't sealing i suspect you'll hear and feel nothing! ![]() So, i disagree that this or the oem routing helps seal the rings tighter, but allows them to perform better with less pressure to fight against. WOW! all most lost myself there, don't know if I'm a believer or not! ![]()
#348 |
![]() Join Date: Jul 2005
I Had an idea.
Somebody (not me!?) should install a very sensitive vacuum/pressure gauge on a PCV system from an OEM engine that is in good health. Preferably with a voltage output to be logged vs RPM/boost Then, we can drive the car, and measure the "acceptable" conditions for the OEM engine... And start to modify it, and measure the changes. |
#350 | |
#352 |
![]() Join Date: Feb 2012
Does anyone know if the oil return tube is steel? The tube behind the exhaust manifold that the T on the valve cover originallywent to. I would like an AN fitting there rather than just clamping the hose on the tube. I can't findany info on. It looks like titanium..
#353 | |
My SR20VET |
#354 |
Thank you jr ss. Yes the one in the block but not the turbo drain. The one under the #4 exhaust port. If anyone is interested, I also found a place that sells a 1/2" male bspt to female 1/2" npt fitting for turbo drain. Makes it possible to use 1/2"npt -10 fitting, or any other size you prefer. I guess welding a fitting on would work just fine too.
#355 |
![]() Join Date: Sep 2007
i'm using the stock S13 valve cover set up.
so it should be like this- the part of the 'T' that faces the firewall- has a hose that connects into the port on the motor block. the part of the 'T' that sticks out towards the radiator- has a hose connected to the catch can. the catch can has a hose that connects to the intake pipe, post MAF. correct? |
#356 | |
Yes, Correct!
#357 |
Finished my valve cover recently. I'm excited to test it out. I will be routing to my exhaust with a Vibrant venturi eventually.
I went overboard with the drill. I think it will work fine. My goal is to not need a catch can, period. Roll o' nickels I used all -10 90* Earl's forged AN fittings. I wanted it all uniform. |
#359 |
I love the 13.4 setup. But after the cost of the s14 valve cover and fabrication it was too much for me. I now have over 40 hours in mine after shaving, sanding, polishing, and welding
I will never polish anything again as long as I live.I have thought about doing the 13.4 on my own. Maybe create a jig so that it could be done correctly. I would be willing to do that if I had some interest from people willing to purchase the service. |
#360 |
Ive been trying to figure out an oil catch setup for my sr s13 but im a little iffy on what i decided to do so i want yalls inputs/opinion on it. Other setup suggestions are welcome.
This is what i finnally decided on doing: t-fiitting on the VC that points frwd --> oil catch --> inlet on back of block. Thats the same inlet that the hose from the T (facing firewall) connects to. I would find some sort of atapter that allows both hoses to be connected there. Im not even sure if that will even function right thats why i want to get some more experianced minds on it. The reason im doing this is because my intake/air filter doesnt have a MAF so im basically trying to find a place for the hose thats suppose to go there. Another thing i want some more opinions on is the pcv. The previous owner had it closed off with a rubber cap, will that be fine or should i reconnect it, maybe put a breather on it, idk? Ive thought welding a fitting to my air filter but thats plan B, if yall tell me my current routing wont work. Any help will be greatly appreciated. Thanks. |
