![]() Join Date: Jun 2007
![]() Feedback Score: 15 reviews
Selling this since the 240 is gone anyways. Great item to have for your car!
Pretty sure it's S14 only as I haven't owned an S13 with a consult port yet. I might be wrong though? "The R-VIT (Racing Vehicle Information Technology) is a state of the art monitoring system that can read and display up to 20 different types of Real Timer information provided by the factory ECU. The R-VIT is a fully digital monitoring device with 5 different types of digital displaying capabilities (Needle Meter, Ellipse Meter, Bar Graph, Triple Monitor, and Six-fold Monitor). The R-VIT feature peak-hold recording, playback features, that can record and replay up to 99 seconds (you can stop the replay at any instant to compare a certain parameter versus another, eg, air flow sensor voltage versus rpm). Limits can be set in flash (red light, as in a shift light) and audible warnings to notify the driver of different engine variables, thus reducing the chances of damaging the motor. The R-VIT can communicate with the SBC i-D boost controller via INFRARED to operate the speed and tachometer, OPT 1/OPT 2 readings." Here are just some of the things it can be programmed to monitor at all engine operating speeds: -ignition timing (VERY useful in tuning) -speed -RPM -02 sensor voltage (narrow-band, but still gives you an idea what your A/Fs are) -water temperature -injector pulse (in ms)-allows you to determine what duty cycle your injectors are running at, and if they're "maxing out" or not -battery voltage -air flow sensor voltage -throttle voltage Price is $150obo shipped
96 S14 w/ Kouki Front 05 Yamaha YZF600 |
