I have a 95 240sx that I have had for about 3 months now,
One day my car died in middle of driving so I replaced the maf and knock sensor I had no problems ever since then. Now it tends to get hotter than it should, just got home from work and as I pulled up into my drive way the car had little shakes. I roll down the window and it was "galloping", every component in the engine bay was really hot to the touch, battery, air intake ect.. The oil is not milky, the temp gauge works perfectly fine, no air in coolant. The only thing that is not connected is the air intake sensor, due to the wires being messed up, I just got a new one on the way. I'm not sure it's just really hot and nothing seems to be wrong. Please help me, thank you. |
![]() Join Date: Jul 2005
"please help... theres nothing wrong with my car... but something is wrong with my car"
Try taking pictures and videos of the various issues do a compression test get a real water temp gauge on it do a tune up get pictures of the plugs make sure theres no oil in the cylinders |
^This
Also, If that check out, no oil in cylinders, good plug color, then check your clutch fan and thermostat. Thermostat can be replace in about 15 minutes and then re-burp the system. Also, when did this overheat happen, in traffic, hot day, or normal driving conditions? |
Op just load it off on a unsuspecting buyer for cheap (me) for say.....500-600
Seriously having a problem and then just replacing parts doesnt solve issues it creates more. Basic diagnostic skills are required and arent hard. |
#6 | |
![]() Join Date: Jun 2003
Trader Rating: (129)
ummmmmm WAT? WHAT is causing you to think its "hotter than it should be"? please provide actual measurements and values, not "shit next to the engine is too hot to put my hands on" |
| help 240sx, hot |
