![]() Join Date: Oct 2007
z32 tt caliper spacer sizing (help)
my rims are 18 x 9 +25 offset ..i need too find out what size spacer too run so the caliper does not hit the wheel thanks alot
What kind of spoke design do your wheels have?
Spoke design is more important than wheel offset man... |
r33gtr wheels are 9j et30 and require a 10mm spacer.but it really depends on the wheel design.
what i usually do it jack the car up take the wheel off then lower the car down onto a block of wood under the chassis rail so that it is at ride height then put the wheel back on the studs at where i think it should be and measure the gap.that should determine what spacer you need |
Low disk Minervas are probably going to need a huge spacer to clear it, seeing as blackcoupe said it took a 25mm spacer to clear his Z brakes, and his were the A-disks (normal disk I think).
Here's the post: #/f/chat/129865-whee...ml#post2605784 |
