NRG Short Hub, ARC Intercooler, Nismo Shift Knob, Radiator, Test Pipe SR Partout!
Located in Queens, NY
Shipping under buyer's expense + 3% pp fees PM or call/text (347) 676-0389 PayPal address is [email protected] Trades: Red Bride BRIX I, Ergo I, Defi BF Amber Gauges, ARC stuff, Tanabe Sway Bars, Blitz BLM Gauges, Type X rep lip, Ganadors, any cool s13 goodies. I am fully parting out my S13 SR. Everything's for sale, if you don't see it then PM me. I got all misc. bolts and nuts like tranny bolts, etc. PM me for pricing. I do not accept refunds, all parts are in working order and condition as is pictured. 3" Test Pipe - $25 Buddy Club Spec II silencer Brand New, could fit other exhausts too - $30 Welded Diff (no pumpkin, drop in and go) - $40 SR blue silicone hoses upper one cut for temp sensor - $50 S13 SR Complete Bottom End - $180 Stock Waterpump Pulley painted blue - $25 Stock Manifold Heat Shield - $25 Turbo Lines - $25 T25/T28 Oil Drain Hose - $20 T25/T28 Turbo to Manifold gasket OEM - $10 IACV (works fine) - $70 Alternator bracket w/ bolts - $35 Water Inlet - $20 TPS - $45 Throttle Body - $35 Knock Sensor - $35 Mr Gasket Copper Exhaust Gasket - $15 Stock Intake Manifold - $40 Gates S13 SR20DET Heater Hoses w/ Clamps (for those doing swaps, perfect fit) - $40 S13 Non ABS manual driveshaft - $65 S13 Windshield Washer Bottle - $15 S13 ARC Side Mount Intercooler w/ smic piping setup - SOLD Nismo Leather Shift Knob - SOLD NRG Short Hub Mint Condition - SOLD RARE NEW Blitz Horn Button - SOLD JVC cd player/aux headunit - SOLD S13 Radio Brackets - SOLD Stock SR Radiator - SOLD S13 SR Water Outlet - SOLD Coolant Lines under the manifold - SOLD Coolant Temp/Dash Gauge Temp Sensors and Housing - SOLD S13 SR Blacktop Head Complete and Mint - SOLD S13 SR 5 spd transmission - SOLD Stock Garrett T25 turbo - SOLD T25 Inlet Pipe w/ gasket - SOLD T25 Outlet Pipe w/ gasket - SOLD T25 Oil Drain Tube - SOLD T25/T28 Turbo to Elbow gasket OEM - SOLD Stock Turbo Elbow - SOLD HKS Turbo Actuator - SOLD Stock Exhaust Manifold - SOLD KA/SR B&M Short Shifter mint condition - SOLD S13 ISIS 3" Dual Tip Exhaust - $SOLD Wiring Specialties S13 SR into S13 upper & lower harnesses - SOLD Type X SR20DET J4 stock ECU - SOLD Stock 370cc injectors - SOLD S13 Fat Blacktop O2 Sensor - SOLD Coil Packs x4 - SOLD Coil Pack Harness - SOLD CAS - SOLD OEM Coolant Tank Reservoir no cracks or leaks- SOLD Powersteering Pump and Bracket - SOLD Motor Mount Brackets - SOLD SR Alternator - SOLD Greddy Divided Turbo Outlet - SOLD Apexi Power Intake - SOLD Purple Samco Radiator Hoses - SOLD Nismo Motor and Tranny Mounts - SOLD Nismo Thermostat - SOLD SR20DET Purple Togue Factory Pulley Set - SOLD Z32 Fuel Filter and hose - SOLD Starter w/ bolts - SOLD Brand New S13 SR20DET Fan Shroud - SOLD SR20DET stock intake hose - SOLD SR20DET Ignitor Chip - SOLD Circuit Sports BMC Heatshield - SOLD Walbro 255 lph Fuel Pump - SOLD RS*R Downpipe - SOLD ECU Brackets - SOLD Radiator Stays - SOLD Din Pocket - SOLD Circuit Sports SS Turbo Lines - SOLD S13 SR20DET MAF (52F00) - SOLD Tomei Rocker Arm Stoppers New in Box - SOLD Manual Trans Crossmember - SOLD HKS Turbo Timer - SOLD Last edited by leung; 10-25-2012 at 02:18 PM.. |
![]() Join Date: Sep 2009
Trader Rating: (91)
![]() Feedback Score: 91 reviews
Bump for a legit seller. Just to clarify the intercooler is indeed a CA unit. Works for SR as well though.
www.monkeyboysyo.blogspot.com |
