Old 05-14-2008, 04:30 PM   #1
handinpants
FreshColdBeer.com
handinpants's Avatar
Trader Rating: (48)
handinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud ofhandinpants has much to be proud of
Feedback Score: 48 reviews
Send a message via AIM to handinpants
Buying 550cc side feed sr20det injectors on ebay
I'm searching ebay for Buying 550cc side feed sr20det injectors on ebay 550cc side feed sr20det injectors, i am find deals on used stuff but what i want to know is about these "direct replacement" ones that look like the SARD red 550cc injectors, has anyone bought these unknown 550cc sidefeed injectors before?
handinpants is offline   Reply With Quote
Old 05-14-2008, 06:58 PM   #2
Blown240sx
Blown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymoreBlown240sx is not welcome here anymore
Unknown can mean bad things. With something so vital Id stick with proven parts.
I am the Negative Rep Master
Blown240sx is offline   Reply With Quote
Old 05-15-2008, 08:56 PM   #3
slider2828
slider2828's Avatar
Eh.... buy it and blow your motor... Saving a 100 bux now will probably not save you enough on your engine rebuild.... If you are strapped a little run Deatschwerks. Have them for 2 years boosting 18psi no problem.
Turn and Burn!
Old 05-16-2008, 08:52 PM   #4
handinpants
FreshColdBeer.com
Trader Rating: (48)
douche works
What size and how much were they? Were they drop in
Old 05-17-2008, 12:43 AM   #5
slider2828
slider2828's Avatar
Deatchwerks is a sponsor here of the forum look it up.... I got 600cc
Turn and Burn!
Old 05-17-2008, 10:46 AM   #6
handinpants
FreshColdBeer.com
Trader Rating: (48)
douche works
Old 05-17-2008, 02:38 PM   #7
s13coupedrfter
s13coupedrfter's Avatar
s13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond reputes13coupedrfter has a reputation beyond repute
I had the nismo 555cc injectors in my sr20det and they fit like a glove, no mods needed.
Yesterday I installed the Deatchwerks 550cc direct replacement injectors in my rb25det and they also fit with no mods needed. I really like the deatchwerks because they give you a injector report and they are flow matched within .03% of each other. Fast shipper too!
BTW don't forget to lube the o-rings before install. G/L
s13coupedrfter is offline   Reply With Quote
