![]() Join Date: Aug 2006
Trader Rating: (105)
![]() ![]() ![]() ![]() ![]() Feedback Score: 105 reviews
Hi, I am listing all of the sr20det parts that I no longer need. If you see anything you are interested in, please post or send me a PM. I can take more pictures of any item upon request. Prices do not include shipping, please leave zip code for quote. I accept paypal and ship fast.
OEM head bolts w/ washers-$20 ![]() S13 cams-$70 for pair S13 cam gears-$30 for pair ![]() Oil feed tubes-$30 for pair ![]() Rocker arms-$80 for set of 8 ![]() S13 redtop valve cover w/ T and PCV valve-$70 Valve cover T-SOLD OEM oil cap-$10 ![]() OEM timing cover / oil pump-$70 ![]() Timing chain tensioner-$30 ![]() Crank / oil pump collar-$10 Crank pulley bolt w/ washer-$10 Lower timing chain gear-$10 ![]() S13 pulleys P/S pulley-SOLD Water pump pulley-$10 Alt. pulley-$10 ![]() Thermostat housing-$20 ![]() Temp sensor harness-$15 Water outlet-$30 ![]() Water inlet-$20 ![]() S13 intake manifold-$30 ![]() Intake manifold brackets-$20 for all 3 ![]() PCV valve to intake lines-$20 ![]() Coolant lines under intake manifold-SOLD S13 throttle body w/ auto TPS-$60 ![]() Auto TPS-$30 ![]() SR20det injectors(great condition)-$80 for set Injectors caps w/ bolts-$15 for set ![]() S13 fuel rail-$30 ![]() FPR-$15 ![]() OEM exhaust manifold-$40 Blacktop rods-$80 for all 4 ![]() Crank girdle-$40 ![]() Girdle baffle-SOLD Main bolts w/ washers-$20 ![]() Oil pickup / strainer-$25 ![]() Oil dip stick w/ housing-$25 ![]() Dip stick housing-$10 ![]() Knock sensor harness-$20 ![]() Rear seal housing (one tab broke)-$15 ![]() SR engine flex plate-$40 ![]() SR OEM flywheel (resurfaced then used for 5k miles)-$50 ![]() SR flywheel bolts-$20 for all 8 ![]() Throwout bearing sleeve-$10 S13 complete manual driveshaft non abs-$120 ![]() SR / KA engine brackets-$40 for pair ![]() Skyline engine mounts (240sx upgrade, solid rubber)-$120 ![]() J4 type x blacktop engine harness (complete and uncut)-SOLD S13 sr20det to s13 240sx plug n play engine harness-SOLD Redtop sr20det ECU-SOLD Sr20det ignitor chip (small chip underneath)-SOLD Coil packs in great condition-SOLD Coil pack harness-$30 ![]() T28/GT28 bottom mount turbo line kit (steel braided water lines, hard oil line, AN fittings, banjo bolts, and washers)-SOLD T25 water inlet line-$10 T25 oil feed line-$10 Water line banjo bolts-$5 each ![]()
PM me for s13 or s14 parts! Last edited by s13 drifta; 04-23-2014 at 12:35 PM.. |
DIF Goodridge T2 bottom mount return line-$40
Mishimoto radiator cap-$15 ![]() CAS (has chip on plug, harness plugs in)-SOLD IACV (metal screw)-$70 ![]() Power steering pump complete with banjo bolts, bracket, and pulley-SOLD ![]() S13 power steering bracket with bolts, tensioner, and tensioner bolts-SOLD S13 high pressure power steering line-$50 ![]() S13 power steering hard line-$40 ![]() SR alternator-$70 ![]() Alternator bracket, bolts, tensioner bracket, and tensioner bolts-$40 ![]() S13 SR OEM water pump-$30 HKS 2 bolt compressor inlet-SOLD OEM 2 bolt compressor inlet-SOLD ![]() SR OEM upper radiator hose-$10 ![]() S13 OEM SR MAF-SOLD Q45 MAF-$50 OEM intake-$30 ![]() HKS direct drive purple air filter-SOLD S13 SR crank pulley-$50 ![]() Oil sandwich plate-$30 ![]() All bolts bagged and labeled (let me know what you need) ![]() SR20 manual transmission-$290 ![]() S13 manual tranny bracket-$40 ![]() Greddy aluminum cold pipe for stock manifold (small wear spot)-$50 Greddy Type S BOV Proven Performance edition-$120 CX racing 1 piece dump and downpipe (flex section is a scraped on bottom, doesn't leak)-SOLD 240sx B&M short shifter-SOLD Blitz Dual SBC electronic boost controller-$180 MSD coils P/N 8224, $44.95 each new-$20 each ![]() Vortech FMU 12:1-$80 ![]() Billet BOV w/ pipe-$40 ![]() 28x6.5x2.5 FMIC (little tweaked, still works good)-$30 ![]() Autometer fuel pressure gauge w/ steel braided line-$30 ![]() Thanks for looking!
PM me for s13 or s14 parts! Last edited by s13 drifta; 04-23-2014 at 05:17 PM.. |
![]() Join Date: Aug 2009
Trader Rating: (77)
![]() Feedback Score: 77 reviews
The Biggest SR20DET Parts Thread! Over 80 Pictures! OEM & Aftermarket! Must L...
Might hit you up for some parts. Free bump for one of the most organized FS threads.
Sent from my iPad using Tapatalk
#13 | |||
I have to check my spare harness to see if it's still there.
Yes, I have one. Just have to find it. $42 shipped. Let me know if you want it.
PM me for s13 or s14 parts! Last edited by s13 drifta; 01-10-2014 at 06:59 PM.. |
#25 | |||
Yes, I can put together a whole complete kit for you.
PM me for s13 or s14 parts! |
