dose anyne know where i can se a pic of these??? and dse anyone know if they will fit on a 92 fastback???
thanks in advance... craig |
are you trying to say that you want to see what your rims would look like on your car.........if so go to www.goodroadsauto.com and then there should be a button on the bottom that says good wheels. once you click it pick a car and a set of rims. you can even drop it and change the profile of the tires
Guest
Posts: n/a
no those rims won't fit on the 92 its four lugs as opposed to 5 on the 95
Guest
Posts: n/a
only 95-98 US spec SE's were all 5 lug
