Old 12-25-2012, 09:37 PM   #1
FourtyKid
FourtyKid's Avatar
FourtyKid is an unknown quantity at this point
SR Are my vacuum lines hooked up right?
  • S13
  • SR20DET
  • T28 Turbo
  • HKS SSQV BOV
I'm utterly confused. I can't figure out my BOV/Turbo and I think it's the vacuum lines. I made this huge picture to explain my setup, so read that first. Now, why in the hell would that line make the car die when it's on the hotpipe?
FourtyKid is offline   Reply With Quote
Old 12-26-2012, 06:33 AM   #2
EnemyS15
EnemyS15 is an unknown quantity at this point
Shouldn't that middle nipple on the boost selonoid be vented to atmosphere? Left side to top port of wg and right side to turbo (tee'd to lower port of wg). It's how I have my haltech boost solenoid set up.
EnemyS15 is offline   Reply With Quote
Old 12-26-2012, 09:17 AM   #3
jr_ss
Trader Rating: (34)
Feedback Score: 34 reviews
Yeah, I thought the center port was the "vent".
My SR20VET
Old 12-26-2012, 11:44 AM   #4
FourtyKid
FourtyKid's Avatar
This is my first turbo'd car so I'm still figuring all this stuff out. I have an internal wastegate with a wastegate actuator. The left nipple is going to the Wastegate Actuator. (Red line is left solenoid nipple, green line is middle nipple)
So, if the middle nipple just has the hose hanging free instead of hooked up to the hotpipe, do I need another hose for the right nipple? This is what it looks like...
It's just a solid nippley-cork-thing. Like nothing could pass through it.
Old 12-26-2012, 07:08 PM   #5
EnemyS15
middle nipple/port is to left alone...... here is a diagram for internal wastegate setups.
I googled for less than 5 mins and found your answer. Definitely dig a bit, answers like these are definitely out there.
although this is for a manual boost controller, it's the same thing for electronic.
Technical Articles | Manual Boost Controller Installation | Turbosmart USA
for that model boost controller
http://www.jegs.com/InstallationInst...17-30-2400.pdf
Old 12-26-2012, 07:31 PM   #6
anarchyperf
anarchyperf's Avatar
anarchyperf is an unknown quantity at this point
http://www.aemelectronics.com/Images...%2030-2400.pdf
These are a little clearer than the ones from jegs but it looks like you have it setup just fine. Nipple on left goes to wastegate and center nipple gets boost pressure. To simplify things eliminate the boost controller and run wastegate pressure for now. Connect the wastegate directly to your boost source.
www.anarchyperformance.com - Your source for 240sx Performance!
https://www.facebook.com/anarchyperformance - Like us on facebook
Email: [email protected]
anarchyperf is offline   Reply With Quote
Old 12-26-2012, 09:05 PM   #7
ultimateirving
ultimateirving's Avatar
ultimateirving is an unknown quantity at this point
also are you getting flutter? or what?
If the HKS unit is adjustable and its not opening it could be at too stiff of a spring pressure.
This too, it is the easiest way to initially set up your blow off valve because you can make sure nothing else is interferring
Z32 with lq4 swap
Desert Street Scene || Dssevents.com
ultimateirving is offline   Reply With Quote
Old 12-28-2012, 04:30 PM   #8
FourtyKid
FourtyKid's Avatar
"Boost pressure" means the hotpipe nipple, like on this picture right?
[Green lined hose is the center nipple, red is left nipple]
Old 12-28-2012, 04:32 PM   #9
anarchyperf
Yes the hotpipe is fine. It also looks like that hose is way to big and not on there very well.
Old 12-28-2012, 04:34 PM   #10
FourtyKid
FourtyKid's Avatar
Ok, see that's my problem. When I have it hooked up just like that, the car dies. Take it off the hotpipe and it runs like a champ. I don't understand it.
And yeah, I just had it on there for a quick picture.
Old 12-28-2012, 04:48 PM   #11
anarchyperf
hmm... How does the car run otherwise? Have you tried it with the maf disconnected? Sounds like your running way to rich and when you take away that extra air at idle it chokes.
Old 12-28-2012, 04:59 PM   #12
FourtyKid
FourtyKid's Avatar
Yes, I've tried it with the MAF disconnected and it ran alright, but that was without the hose hooked up. I know I'm running rich because of this that's going on in my trunk.
Old 12-28-2012, 06:57 PM   #13
anarchyperf
I doubt that is making the car run rich. Looks like they just rigged a way to turn on the fuel pump. The stock fuel pressure regulator should still be doing it's job.
Old 12-29-2012, 02:50 PM   #14
FourtyKid
FourtyKid's Avatar
That makes sense.
