![]() Join Date: Sep 2010
Help a noob go back to factory/OEM radiator
I have an SR20det S14. The cooling setup is currently a Mishimotor radiator + dual electric fans, with no shroud. I'd like to go back to completely stock / factory setup, with the exception of maybe using a larger RB fan (Yashio Factory style).
Can someone help me with what all I would need, and part #'s too, if possible? I believe everything I need is as follows: 1). Factory S14 Radiator (can't find part number) 2). SR20det Fan Clutch #21082-52F00 3). S14 Upper Fan Shroud #21476-65F11 4). S14 Lower Fan Shroud #21477-35F00 5). SR20det Fan Blade #21060-52F0A ~OR~ RB26dett Fan Blade #21060-5L300 If anybody can confirm/deny that those parts are everything I'll need, and whether or not the part #'s listed are correct, it would be greatly appreciated. Thanks! |
