![]() Join Date: Mar 2012
92 Coupe nissan 240sx 2jz swap
1992 Nissan 240sx Coupe
Exterior Oem aero bumper Half/half turn signals Oem metal fenders Oem metal hood Oem type x side skirts Panda garage rear valences (rare) Oem bricks Dmax wing Megan racing cf roof wing 5 year paint job regal black Shaved side markers Shaved antenna Oem windshield Manuel doors Electric lock 2 way pager/alarm 25mm pulled front and rear fenders Suspension S13 powered by max coil overs S14 bent style lower control/tension rod combo arms S14 limit break forged knuckles S14 pro caster plates Pbm inner tie rods Pbm outter tie rods Chase bay ss rack lines Custom power brace Pbm solid rack bushings Pbm hood spacers Pbm rear lower control arm Pbm rear traction rod Pbm rear toe rod Pbm rear camber arm Pbm rear subframe risers Pbm rear diff solid bushings Sikky 32 mm sway bar Circuit sports solid steering rack bushing 25mm rack relocated forward 5 lug conversion Ss brake lines R33 big brakes DBA front rotors Z32 rear brake set up Q45 vlsd diff 3.7 gears Q45 passenger axel Drive shaft shop driver axel Pbm spline lug nuts plated reinforced subframe orange Interior Momo 350mm steering wheel Jdm kph cluster S14 front seats S14 rear seats Pbm shifter Pbm ebrake drift button Clean non cracked dash 6x9 speakers Greddy 30psi boost gauge Aem x series wide band Aem xseries temp gauge Engine bay Shaved/tubbed/stitched front end Custom colored root beer brown Chase bay 180 f fan relay Excessive motor mounts Excessive mount brackets Excessive tranny mount Excessive tranny brackets 2jzvvti single turbo Borg Warner sxe 363 turbo t4 .88 ar open scroll Rev tubular manifold open scroll Turbo smart 44mm waste gate 14psi spring Turbo smart bov Polished housing Ceramic coated rear housing Ptp turbo blanket Atg -4 oil feed line Speed factory Titanium manifold studs and hardware 3 ? piping Speed factory Supra Intercooler (1000 rated) Engine bay tucked hardness Wire specialty style wire hardness Aem dry flow filter Aem dry flow filter blanket (water proof) 3? down pipe 3.8? custom powered by max oval exhaust Pbm oval burn tips Custom painted valve coil pack cover Polished valve covers -10 oil jegs catch can Late model jdm r154 low miles shifts smooth Clutch masters light flywheel Custom south bend clutch single disk (700 rated torque ) 3? one piece drift shaft Daft innovation Wilwood bracket Wilwood clutch master cylinder Walbro 255 fuel pump + relay Dekota digital speed convertor Dekota digital rpm convertor Toyota oem ECU New gates racing timing belt (blue) Oem tensioner Bc racing cam gear New oem timing cover (bottom) New oem water pump New oem valve cover gaskets New oem ventilation hoses 485 hp/411 torque @ 14psi Clean Title Tags are current sold as is (NO SMOG) FIRM 16k Will trade for a MKIV Supra Show me what you got no other trades. 2096486692 Text is best https://photos.app.goo.gl/onGmoQ9txmJ9r5Cd8 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Sent from my Pixel 3 using Tapatalk ![]() ![]() ![]() Last edited by Ros7.exe; 10-13-2020 at 11:49 PM.. |
#4 | |
and Turlock, CA 95382 Yes need to take some later today |
Thank you guys for the interest. Sorry to everyone we couldn't make an agreement. I'll be taking the ad down and closing the thread.
![]() Sent from my Pixel 3 using Tapatalk |
