#121 |
![]() Join Date: Dec 2002
Project INCOGNITO Update
Black FMIC Black Hood-Pins Black Exhaust Tips Less Tint Shift at 2200 Boost & BOV EVERY GEAR ON THE I-5 HOME.
#122 |
![]() Join Date: Mar 2003
more Touge miles logged.
more conscious improvement of driving acheived shifting improved heel-toe almost seamless . . . . . . time to work on extreme slip angle driving
In life, we often cast the line of hope fishing for the best possible opportunity. Sometimes with enough effort, the things we catch are nothing short of amazing. |
#123 |
91 Z32 TT, 92 Z32 TT, 90 240 LSX in progress, 09 GT-R, 18 Honda Ridgeline |
#124 |
![]() Join Date: Dec 2001
car: 1990 240sx
trim: se color: red (different shades) body style: coupe engine build plan: naturally aspirated current power rating: n/a modifications: K&N Drop in filter Tokiko springs (1 in. drop) PDM Bushings all around S14 seats / seatbelts Weight reduction: removed auto seatbelts front metal bumper plan modifications: early 89 SOHC rebuilt motor (9.1:1 compression) new clutch paint |
#125 |
1995 240sx base
SE lip SE spoiler SE foglights SE rear sway bar sunroof wind deflector 16" RP0-1's KYB GR-2s sprint springs 1.8" drop front STB AEM short ram - soon to be custom really short ram 2.25" custom catback with JTC dual tip muffler relocated battery to back aluminum subframe spacers energy suspension bushings HKS style ground kit removed clutch fan Navan style grill shaved emblems black w/blue pearl paint job dark tint new nissan clutch genuine leather shift boot+e-brake handle leather nismo shift knob short shifter (brand unknown) 93 tranny in the works 93 ka24de with 90k in the garage header (brand unknown) down the line carbon fiber hood ASP pulley vlsd q45 brakes more suspension upgrades |
#126 |
91 hatchback
Black, 30mm wide front and rear fenders Carbon fiber hood GP sports type R front GP sports G Sonic side's and rear bumper Volk GTC's 17x9 and 18x11 TEIN HE's S/T sway bars Powertrix Tension rods Brembo cross drilled rotors 5 lug setup VLSD S14 SR20DET Hybrid front mount Intercooler lightened stock flywheel URAS stainless exhaust JGY stainless down pipe More to come!! |
#127 |
![]() Join Date: Jan 2003
well here i go even tho its not all actuallyin teh car, but at least its in my garage being prepped to go in, time is teh only thing lacking right now.
Car: 1991 Nissan 240SX SE Body: Fastback Color: Metallic Grey miles: engine 30k, body 182k Current Mods: SR20DET black top from 1994+ 180sx (stock boost) OS Giken SuperSIngle Clutch Veilside Tuned ECU Greddy Downpipe SS Autochrome turbo Manifold (equal length runners) SS Autochrome Turbo extension 3" SS Autochrome Catback exhaust 3" NGK R Sparkplugs Gates belts Magnaflow 3" Catalytic Converter HT Hotpipe Greddy Type-S BOV Greddy RSPL FMIC Nismo Motormounts Nismo Tranny Mount B&M Short Shifter Walbro 255lph fuel pump JDM Radiator NEW Fuel Filter NEW Oil Filter New turbo gaskets DT-05R wheels on order Falken Azenis Race tires 215/45R16 Nissan Altima Brakes (came with clip, and were much bigger than stock brakes, so swap was a must) HICS all operational (JDM HICAS PS pump) ABS operational VLSD (boooo) Desired Mods: (All desired mods will be done by September) S13 Front end swap PDM sideskirts PDM rear valence Bomex Front lip from S13 front end Autopower Rollbar Greddy Oil Pan HKS Turbo Timer HKS Boost Control Kaaz 1.5 way LSD
***NASA HPDE Instructor*** |
#128 |
Admin Asshole
![]() Join Date: Mar 2002
1993 240sx Coupe
Mostly Primer Stock Black steel wheels, no Hubcaps Half Dead KA24DE w/ Bad Automatic Tranny Shaved side markers, antenna, trunk lock, and spoiler holes East Bear Mirrors in transit, will be put on when they arrive I'll be deploying in January for 9 months, when I return hopefully I will dropping in a Redtop SR, and finishing the body.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#129 |
1995 Zenki S-14 Silvia
Green S-14 Engine: 1.8mm Head gasket S-15 480cc injectors HKS 264 cams Sard FPR 60mm Throttle body (From S-14 Q's) 230lph Z32 fuel pump stainless steel exhaust manifold stainless steel down pipe with open dump pipe HKS act. HKS SQV techno sports EPROM TUNE FEETS WURK: FRONT: JIC tension rod JIC tow control rod JIC TIE rod REAR: JIC upper camber rod JIC tow control rod JIC caster control rod JIC front adjustable shokojou with JIC camber plates TEIN Rear adjustable Shokojou Keiichi Tsuchiya 17x8 fronts 17x9 rear rims electronics I have Defi link BF WATER BOOST OIL PRESSURE EHAUST TEMP FUEL PRESSURE OIL TEMP TACH with the controller all 62mm Greddy Profec A Stepping motor boost controller |
#130 |
![]() Join Date: Jan 2004
first:
1- fix dents, paint trim, and body (daytona blue) 2- replace worn bushings and fix minor suspension issues 3- LSD 4- black interior to replace broken/worn/faded components (with racin seats and steering wheel) next: 5- wheels 6- decent coilovers 7- Z32 brakes then: more power |
#131 |
![]() Join Date: May 2003
my brothers S13 coupe (Ive done all the work and made almost all the decisions..i drive it more than he does)........only worked on itfor 4 months now
*next to what im going to do Suspension Tien He coilovers- cusco strut bar Tien te rods *Plan on doing a lot more here Breaks and Wheels (all the wheels are mine) Kei office 5 spokes (4) Advan SA3 (2) Enkei Riken mesh (2) Hawk brake pads brembo rotors Engine Sr blacktop Greedy Fmic Uras ti exhaust (took 3 months to come!!) Interior Recaro SRD seats w/ custom sliders Nardi steering wheel Trust shift nob Exterior S13 conversion Q's front bumber w/lip Painted Rally Blue (WRX) This isnt technically my car but ive dont most of the work and i drive it more than my brother does.....but yeah its hot
-Austin ![]() My name is Shake-Zula, the mic rulah, the old schoolah, you wanna trip, I'll break it to ya. Frylock and I'm on top rock you like a cop, Meatwad you're up next with your knock-knock. Meatwad make the money see, Meatwad get the honeys G. Drivin in my car, livin like a star, ice on my fingers and my toes and I'm a Taurus. Cause we are the Aqua Teens, make the homeys say ho and the girlies wanna scream. |
#132 |
car:95 240sx
trim:base color:LN1 Factory (I call it purpley blue) body style:coupe engine build:naturally aspirated ka24de current power rating:n/a engine modifications: K&N intake NGK Iridium spark plugs Ractive ignition wires high flow down pipe 3" stainless catback exhaust suspension modifications: KYB AGX adjustable shocks/struts adjustable camber arms Drop Zone lowering coils (1.8") front strut tower bar rear strut tower bar rear lower tie bar Energy suspension polyurethane bushings:front upper and lower control arm bushings,front sway bar bushing and endlinks,tie rod boots,and strut rod bushings. Apperance Modifications: Nakayama Triton 6 17x7 bronze rims Toyo FZ4 215/40/R17 tires JDM spoiler JDM rear bumper(have but not installed yet) JDM side skirts (have but not installed yet) SE model fog lamps Maltice cross custom mesh grill Xenon Bulbs(high and low beam) PIAA Platinum side marker bulbs blue LED reverse lights nismo floor mats Custom made maltice cross speaker grills Nismo oil cap Brake Modifications: Brembo drilled slotted rotors f+r Project Mu Brake Pads F+R Stainless steel brake lines audio modifications: Pioneer 180 watt Deck with changer controls and XM radio Pioneer 6 1/2" Mids (rear) Pioneer IMPP 12"Woofer (700watts) Clairion 51/4"componet set (front) Clairion 700 watt AMP Pioneer 6 disc CD changer Planned Modifications: ka24 rebuild FMAX stage 1 turbo kit headers pulley set 272 degree cams cam gears jet ecu chip auto to manual swap aluminum radiator oil cooler HKS fuel pump nitros with 50 shot tip copper head gasket custom hoses cryo treated crank shaft turbo timer fuel computer stage 3 clutch aluminum flywheel short shifter tanabe transmission bushings cusco 2way LSD rear adjustable traction arms rear adjustable toe arms HKS front adjustable strut mounts rear upper and lower polyurethane control arm bushings rear sway bar and poly bushings Endless big brake kit Leather upolstery 2 tone black suede headliner Painted dash,door panels etc. 3 tone match exterior purply blue,bronze and black New black carpet custom sub enclosure in spare tire well suede trunk lining carbon fiber hood Clairion 6 1/2" mids Clairion 6 1/2" component set PS2 Clairion LCD Screen New battery Cobra MAF Painted valve cover to match exterior all components painted and polished 18" rims in back preferrably Nakayama Triton 6 bronze 18x8 power folding mirrors addition of cruise control HKS FM intercooler Kouki tail lamps new paint job (original color) |
#133 |
car: 1995 240sx
trim:SE color: Blueish GReen engine build plan: Turbo one day current power rating: n/a Current mods: HKS Hi-power Exhaust Injen Cold Air intake w/ Cold air extension Eibach Springs and Toticko Shocks OBX Short Shifter VIS Racing Cabon Fiber hood Future Plans: Coilovers (silk road, tanabe or SPL Parts) LSD (Nismo 1.5 Way) Wheels (Volk TE-37's) More then Likely an SR when the funds become availible...
1995 240SX SE - Sold |
#134 |
![]() Join Date: Aug 2002
1995 240sx SE
Suspension: -Eibach Sportlines(hella old) -Tokiko blue's (shit's are blown) Exterior: -No grill -Almost Debadged -optional wing (no wing days) -Some Sticker's Interior: - Nothing but a crystal clear bubble shift knob Tranny: - 97 Silvia k's vlsd - 80w 90 synthetic tranny oil( i forget what oil is in the vlsd). Motor: - Injen intake w/HKS mega flow filter - Trust Headers - HKS Hi-Power exhaust Wheels/Brakes: - Riken Mesh 16x7 -15 / yokohama es100 205/55/16 F - Super Advan SA3R black with blue lip 17x9 +42 potenza RE-01 235/45/17 R - Super Advan SA3R black with blue lip 17x8 +32 potenza RE-01 225/45/17 F - Stock SE's back up on some shitty ass tires - Rear brembo rotors / hp hawk pads (pads are super worn out and are bare metal thanks to having a fucked up master cylinder) - stock front pads Things still waiting to come on/future mods - - Gotta clutch thats waiting to come on sitting in my room - Oem Master cylinder - Oem Slave cylinder Coming Very soon - Tein He's - Front and Rear STB of some sorts - New Rims (maybe J-lines, but i really want...........) - RUCA's - New Bushings All around - T/C rod - Tie rods/end
kick rocks. |
#135 |
car: 1996 240sx
trim: se color: black body style: coupe engine build plan: turbo? modifications: Kazama- rear camber adj. control arm. kazama- rear toe adj. control arm. kazama- front tension rod. kazama- tie rod endlink uras- tie rod largus- sway bar nismo- front lower control arm nismo- rear front control arm ikeya formula- adjustable rear lower a arm tokico- shocks tein- s. tech cusco- pillow ball camber adj. strut plate rsr- exmag II act - 4 puck with extreme pressure plate plan modifications: some rims front nd rear strut bars nismo underbrace fender brace fix bumper seats |
#136 |
![]() Join Date: Feb 2004
Car: 1992 240SX SE coupe
Mileage: 203k chassis, ~90k engine Color: Black/White/Burgundy Transmission: 5-Speed Manual Engine Mods: - Apex'i panel filter - drilled out airbox -'95 engine swap Suspension Mods: - KTS coilovers - Powertrix subframe spacers - Pro Spats front strut brace - 205/50R-15 Falken Azenis Sports - Kyo-ei 10mm spacers Drivetrain: - J30 VLSD - Nismo 60mm lug studs - C's shortshifter - new OEM slave - random KA24E tranny swap Brakes: - Axxis Ultimate pads - Ate Superblue fluid Body: - Silvia K's front end conversion, twin projector - ghetto fab paintjob - hood lift - Bush/Cheney '04 magnetic bumper "sticker" Interior: - Sparco Sprint seat custom-mounted on stock sliders - random 350mm steering wheel - HKB hub - Panda Garage spline-type quick release - Nismo shift-pattern sticker - Nismo GT shift knob - Rigid Racing drift spin e-brake super sideways sliding ultra turn knob - 300mm rearview mirror - Tweed door lining delete - brake pedal extension - accelerator pedal spacer/extension Future: (not in order) - new tie rod ends - new tie rods - new t/c rods - good transmission - Nismo engine mounts - pretty much every SPL adjustable suspension piece - SPL braided clutch line - stainless brake lines - Whiteline adjustable swaybars - Urethane steering rack bushings - Nismo power brace - SPL fender braces - SPL rear subframe braces - aftermarket LSD, 1.5-way - battery relocation - Optima lightweight battery - custom-painted Hotshot header (so it looks more stock) - CAI - tuned ECU - lightweight flywheel - aluminum driveshaft - PDM cams - 3" cat-back 5Zigen Rocket/Border 304/RSR ExMag GTII/HKS Hiper - rear triangulated strut brace - Sparco Evo/Pro 2000 seat - roll bar - Sparco four/five-point harness(es) - a car that actually looks like a person painted it, rather than an errant orangutan with a rattlecan - C Tune Silvia Aero copy front bumper - Silvia sideskirts - Silvia rear aero bits - front diffuser - Wangan wing (looks purdy, probably doesn't do jack-squat) - f/g or c/f hood - f/g or c/f OEM-style and size fenders, maybe subtly flared 20mm - f/g or c/f trunklid - one set of 15x7ish meshies - one set of 15x7ish Work Equip 03 - one set of 15x? Watanabe F8 - one set of 16x8 meshies - one set of 17x7 Volk CE28Ns - maybe Z32 brakes |
#137 |
![]() Join Date: Jun 2004
1995 240SX SE
Motor: S14 SR20DET S15 Turbo Apex-i Intake Nismo Motor/Trans Mounts GReddy MX Downpipe GReddy FMIC GReddy Profec B-Spec II Blitz Turbo Timer FATT RSR Ex-Mag exhaust (80mm) OBX Shifter Suspension: Eiback Sportlines KYB GR-2 Struts Battle Version tension rods Tein Tie-rods/ends GReddy Front S/B Cusco Rear S/B Brakes: 300ZX F/R 300ZX M/C Slotted/Drilled Rotors Steel Braided lines, all 4 corners Wheels: Work Termist II (Polished, 17X8F +20, 17X9R +27) Bridgestone Potenza's Exterior: Bomex 3pc Kit OEM Silvia K's Spoiler OEM Silvia Grill Interior: Sparco Steering Wheel/Pedals Grex Shift Knob GReddy Boost Gauge System: Kenwood Excelon Head Unit Kicker Solobaric Sub 12" Sony 1200watt Sub-amp Apline 4-channel amp Boston acoustic highs Monster Cable wiring. Bling: Nismo Oil/Gas Cap Just for fun: Your mom riding shotgun.
S14 Zenki...SOLD!! New Project: 240Z w/ SR |
#138 |
ghetto fabulous S14 zenki
Carbon fiber hood (crunked up) 17x8 +14 Manarays 2-inch lip *daily rollers* 17x9 +14 Manarays 4-inch lip 17x9 +15 FN01RC pair *drift wheels* Custom subframe spacers J30 VLSD B-wave coilovers 10kg/8kg Tein tie rods Tanabe tension rods eBay-APEXi knock off front strut bar eBay-Cusco (I call it Kusco) rear strut bar 2 1/4'' test pipe 340mm steering wheel with -50mm offset 50mm steering wheels hub spacer 50mm NRG quick release Sparco speed seat (with no rail~!) Future plans: Tomei Technical Traxx Advance 24-plate Custom fabricate a roll cage, Nismo power brace and Do-luck rear crossbar. Falken Azenis ST115 (freakin awesome tires) JDM "oh-shit handles"
Trust and I don't mean GReddy. |
#139 |
Completed Modifications
Footworks: CUSCO "D" shaped front stress bar CUSCO rear strut tower bar CUSCO rear upper control arms TEIN adjustable T/C Rods Rear SE sway bar 5 lug conversion Greg Dupree Subframe spacers Kei Office XT-a Coilovers R32 Front Brake Calipers and Rotors, Hawk Pads and Front SS Lines NISMO 2 way street LSD Aero/appearance: SE Front and rear Spoilers, fog lights, fog light switch, A-Pillar trim w/tweeters and gauge cluster JDM Silvia hood emblem, front grill, rear badge and K’s side emblems Ergonomics: MOMO shift knob, MOMO shift boot, Pilot motor sports short shifter, CUSCO spin knob, Nokya Racing drilled racing pedal ICE: Alpine 9833 Head unit, Alpine MRV-F450 5 channel amp, Alpine Type R 6 ½” separates (Front) Alpine 6 ½” 2 way speakers (Rear), Eclipse 12” aluminum subwoofer in box Safety/Lighting: HID conversion, Super white parking lamp and interior bulbs, Hella air horns Engine: S14 SR20DET engine (Front clip) S15 side mount intercooler Tomei fuel pump Exedy Stage 1 clutch Trust turbo extension Blitz Stainless Steel down pipe Apex N1 exhaust with 85mm piping Blitz turbo timer HKS boost gauge HKS SSQV Blow off valve Air Conditioning Wheels and Tires: Volk Racing Gram Lights 57 Pro wheels. Front: 17x8 and 18x9, 25mm offset all around Yokohama es100 tires. Front: 225/45 ZR-18 Rear: 235/40 ZR-18 SE Wheels Falken Azenis ST115 tires 205/55 VR 16 all around Future modifications: NISMO Power Bar Bride Brix II seats and rails Zenki S14 OEM Aerokit SE power antenna APEX Power FC 740 cc injectors Blitz FMIC Z32 MAFS Tuning |
#140 |
1991 fastback LE
Motor: 92 redtop sr20det stainless steel clutch line generic filter custom grounding kit turbo xs dual stage boost controller greddy turbo timer 3in down pipe hi-flow cat bent up hks hi-power Suspension: kyb agx H&R springs nismo power brace Tien tension rods subfram spacers pilot motor sports strut tower bars vlsd Brakes: ABS removed, converted to non abs setup z32 26mm up front stainless lines Axxis ultimate pads Wheels and Tires: stock se wheels 215/60 R15 general tires, cheap brand just to get around kosei Rt penta's 225/45/50 R17 x 7.5 Pilot sports up front, bridgestone Bridgeston Potenzas out back Unkown Meshi's 215/60 R14 x 6.5 +15 offset unknown tires on them System: pioner deck Polk audio speakers in front 4x6 boston acustic in back 4x6 $20 Wall mart boom box in very back-- makes a big difference in sound Interior: auto meter boost guage Reupolstered and refoamed seats made to hold me in better driver side cup holder- passenger side broke Future: new transmission/ clutch setup RUCA's Custom intercooler setup Oil filter Relocation Oil Cooler 3in catback to replace bent Hi-power Roll bar More braces Nismo motor mounts t28 turbo Spl coilovers- maybe |
#141 |
Don't let my wife see this. In no particular order for a 96 S14
1995 S14 Silvia Front Clip B & M Short Shifter SPEC Stage II Clutch Fidanza Aluminum Flywheel Cusco Rear Upper Control Arms Whiteline Urethane Control Arm & Sub Frame Bushings Top Speed 3" SS Down Pipe Tein HA Coilover Set, Camber Plates, Pillow Ball Mounts Whiteline Sway Bars Momo Steering Wheel Hub Greddy Oil Pan Greddy SS Turbo Extension Braided Stainless Clutch Line Greddy Profec B Boost Controller Greddy Turbo Timer Greddy Spec R Front Mount Intercooler Walbro 255gpm Fuel Pump Tomei Z32 MAF Adapter Wire Z32 MAF 2 Ga. Welders Cable For Battery Relocation VDO Fuel Pressure Guage OE Shift Boot & Trim Momo Competition Shift Knob Nismo Front Power Brace Tein TC Rods, Tie Rods & Ball Joints Greddy Hot Pipe RSR Invidia 80mm Stainless Steel Exhaust Cusco OS F/R STB's Momo Competition Steering Wheel Clutch Master Cylinder Nakamichi CD-400 Head Unit Dual Flex-A-Lite 12" Electric Fans Apexi Power FC & Commander Tomei 740cc Injectors Clutch Hard Line Moog LCA Ball Joints HKS Turbo Timer Harness Clutch Slave Cylinder Canton Racing Billet Remote Oil Filter Adapter GFB Stealth FX BOV Nismo 60mm Wheel Studs HKS Fuel Reglator Adaptor Aeromotive FPR & Fittings Aeroquip -8 Fittngs for Remote Oil Filter Omori 45mm Oil Pressure, Oil & Water Temp Gauges Cusco Radiator Cooling Panel Stainless Steel Brake Lines Omori 45mm Boost Gauge HKS Racing Suction Kit Greddy Rocker Arm Stoppers Omori 45mm EGT Gauge 80mm Resonated Test Pipe Datalogit Software/Hardware for PFC Energy Suspension Diff Carrier & Subframe Bushings Z32 1 1/16" Brake Master Cylinder Innovate LM-1 Wideband O2 AFM Greddy Differential Cover Koyo Aluminum Radiator Samco Urethane Radiator Hoses Kirk Racing 4 Point Roll Bar C-West Mini Wing Greddy Front Lip Spoiler R32 GTR Wheels |
#142 | |
kick rocks. |
#143 |
car: 1993 240sx
trim: se color: red body style: coupe engine build plan: sr20det swap/250hp current power rating: n/a modifications: KTS Coilovers m2 DT-05R's 17x8.5 f 17x9.5 r some new ghetto installed black carpet zip-tied front bumper plan modifications: ATS LSD sr20det silvia front end conversion bubble shift knob!!!!!!! koyo aluminium radiator electric fan all new suspension goodies maybe a stereo, seeing as I have nada. |
#144 |
![]() Join Date: Apr 2003
95 240sx se:
Burgandy Paint Engine: s14 sr20det Nismo Motor and Tranny Mounts s15 turbo HKS wastegate actuator Blitz front mount Blitz sus intake Blitz Hot Pipe and blow off valve Blitz Nur Spec exhaust Blitz down pipe heavy throttle test pipe Greddy turbo elbow Taka turbo lines ACT Street/Strip TODA Flywheel tomei adjustable cam gear(exhaust) tomei head gasket walbro fuel pump odessy jet ski battery NGK plugs suspension: tein flex coilovers interior: Blitz BLM boost gauge Blitz FATT turbo timer APEX'i EL tach exterior: kouki side skirts zenki rear skirts large dent by trunk, where I kicked it in a fit of rage, word of advice do not fight with girlfriend when drunk. May hurt car. future: z32 brakes lsd rims kouki front paint more suspension mods ejection seat, or settle on recaro or bride fix all of the little shit thats wrong with it go broke and drop out of college |
#145 |
![]() Join Date: Apr 2004
Car: 1995 240sx
Trim: SE Color: White Modifications S14 SR20DET Blacktop Greddy VSPL Front Mount Intercooler HKS SSQ BOV Custom Hotpipe Greddy 3 inch Downpipe Unknown 3 inch Test Pipe 3 inch HKS Hi-Power Exhaust Two 12 inch Flex-a-Lite Electric Fans Walbro 255 Fuel Pump Battery the size for a Miata Carbon Fiber Hood H&R Lowering Springs Clear SideMarkers Just Ordered DT-05R 17x8.5+25 17x9.5+30 In the Future Coil Overs Boost Controller maybe a gauge or two TUNING
#146 |
Inactive Admin
1992 Nissan 180sx Type B (for Busted)
Engine: Stock internals/manifolds/turbine. Apex'i Intake Blitz BOV Unkown JASMA certified 3" N1 style exhaust B-box battery conditioner unknown grounding kit Wheels: Enkei RS-Evolution 16x7 +27 F 16x? +?? R Footworks: SPATS Front STB Apex'i Rear STB unknown spin turn knob GAB coilovers Safety 21 (I think) rollbar Interior: BNR32 seats Alpine CD/MD player Blitz FATT 360mm Nardi Classico Blitz boost gauge Hello Kitty sticker on rearview mirror Exterior: Prontry 180sx clear turnsignals To be installed: eBay (well, YAJ) special pillowball TC rods C's short shifter HKS 3" downpipe Megan racing stainless turbo outlet from Yayspec.com http://www.jspec.com/megansrelbow.html 240sx rear center panel Maybe B-wave wangan wing if nobody buys it from me (only $120! www.fochkopf.com/bwave.htm) |
#147 |
new stuff since my engine blew:
another 91 KA24DE new sohc pistons and rings for 11.2:1 cr 91 exhaust cam fitted as intake cam polished head polished intake mani A'pexi S-AFC vdo oil pressure, water temp, and van gauges (these replace the free sunpros i got) obx header is on its way 3" test pipe is at mr badlose's house, waiting for the header |
#148 |
![]() Join Date: Sep 2002
Don't think I ever posted in this one. Still in the middle of swapping everything over from my wrecked coupe and putting new parts on as well. Been busy.
'93 Coupe SE w/ HUD The Exterior Modifications include: Bomex AD-026 bumper Nismo Fuel Cap S13 Silvia front end conversion w/ Triple projector headlights SilviaParts.com Carbon Fiber GT-R style grille Silvia trunk emblem Security Alarm w/ remote entry The Engine Modifications include: 96 KA24DE engine 3 inch Catco High Flow Catalytic Converter or 3 inch Test pipe Apex'i Super-Air Fuel Control v. 2 (SAFC 2) ASP lightened crank pulley Autometer Phantom Water Temp Gauge Autometer Phantom Electric Oil Pressure Gauge Injen Ram Air intake w/ Cold air extension and heat/splash shield Nismo Radiator cap Polyurethane filled Engine mounts Red Top Optima Battery relocation to Trunk Tanabe Super Madallion Racing Spec cat-back Walbro 255lph fuel pump The Drivetrain/Transmission Modifications include: SPEC Stage 2 Clutch OBX Short Shifter Polyurethane filled Transmission mount The Wheel and Tire Modifications include: 17x7 +38 Lenso VPD lightweight rims White (16 lbs per wheel) (track, autox, & drifting) 215/45/Z17 Toyo Proxes FZ4 tires 17x8 +35 5zigen FN01R-C HyperBlack (street) - No tires yet The Suspension Modifications include: D2 Racing coilovers - 9/7 spring rate Camber plates (front)/Pillowball mount(rear) - installing Nov 6-7 ProjectSilvia Front Strut Tower Bar ProjectSilvia Adjustable Tension rods R32 Skyline Rear Anti-sway bar (26mm) Tanabe Sustec Front Anti-sway bar (30.4mm) Tanabe Rear Upper Control Arms -installing Nov 6-7 Whiteline Aluminum Rear Strut Tower Bar Whiteline Lower Front Control Arm Polyurethane Bushings -installing Nov 6-7 Whiteline Lower Rear Control Arm Polyurethane Bushings -installing Nov 6-7 Whiteline Rear Subframe Polyurethane Bushings -installing Nov 6-7 The Brake Modifications include: ProjectSilvia Steel Braided/Teflon coated Brake Lines R32 Skyline GTS-T 30mm Brembo Rotors (Front) R32 Skyline GTS-T 30mm Calipers (Front) '90 Z32 300ZX Master Brake Cylinder The Interior Modifications include: '95 S14 seats w/ lumbar supports (Front and Rear) 20% Black Tint All windows D2 Racing quick release hub Import Intelligence White Face Gauge Overlays Momo 25mm spacer Nismo GT Black Rubber Shift Knob RedlineGoods.com Leather Shift/E-Brake boots (Black/Red stitching) SPW Steering wheel - 320mm (Black/Red stitching) The Audio Modifications include: JL Audio 10" Subwoofers (2) MTX Blue Thunder Pro 1502 Watt 2-Channel Power Amplifier - Max 400 watts Pioneer Supertuner III Single disc CD player (DEH-P6600) Sony Xplode 6 1/2 inch speakers (4) The Future Modifications include: Turbo KA engine -- GT32e Turbo, SSA top-manifold, S15 injectors, Cobra MAF, JWT ECU, FMIC, and Autometer boost guage already purchased Chargespeed Vented S13 Silvia Carbon Fiber Hood Veilside OEM aero side skirts and rear valances Repaint Entire Car
'11 M56S '12 QX56 (wife's) |
#149 | |
![]() Join Date: Jul 2002
![]() ![]() Feedback Score: 3 reviews
Eclipse head unit pioneer speakers sparco evo drivers seat Bride seat rail Haltech E6X
I never knew you could do that with an eggplant |
#150 |
car: 1993 240sx
trim: se color: green metalic (stock) body style: h/b engine build plan: balls to the wall 2.4 with a turbo current power rating: n/a Engine: ka24de t3 turbo @ 14psi Equal length manifold Greddy FMIC bore .20 over westco piston/rings 8.5.1 ported polished head B&M short throw shifter ACT 2600 clutch kit Fidenza flywheel 370cc injectors Walbro fuel pump Custom fuel rail SARD fpr 85mm HKS Hiper catback 3" test pipe Custom down pipe HKS Super Blow Others: Konig 17's ground controlls on KYB 180 wing 280z hood scoop sleepy eye (due to blown headlight motor) plan modifications: Bigger turbo Bigger Inj. 1.5 LSD and TUNE i did buy this car with a shitty ka set up. with blown rings, the most shittiest IC set up. would hit 11psi then drop to 5. 1 3/4 tubing into smaller Rad. Hose to crushed in/out lets on a starion fmic then to a 3in pipe w/maf then back to a 1 3/4 tube to my TB. So it was a little head start since my previous proj. was stolen and insurance didnt give me shi for the car. but other then the rims the car was pretty much overhauled. though the body was in PERFECT condition for a 93! |
