![]() Join Date: Apr 2008
![]() ![]() ![]() ![]() Feedback Score: 3 reviews
Doing Hub Conversion
Ok Ive Searched And Searched And Didnt Find The Answer I Was Looking For But I Did Learn Alot Of Other Ish.. I Got An S14 4 Lug I Want To Swap The Hubs Out To 5 Lug. Do I Need To Get the Hubs Pressed In Or Do They Just Bolt Right Up?? What Exactly Would I Need?? Just The 5 Lug Hubs Themselves And Thats It??? I Know The Calipers Will Fit The Same Just Have To Get The 5 Bolt Pattern Rotors. But Is That All? Seems Kinda TOO Easy.
Any Help Would Be Great Thanks! |
all you would need is s14 5 lug hubs and bearings.If you get them new the rear bearings and hubs come separate and you would have to press them in.other than that they bolt right up.the only other thing you will need is the 5 lug rotors or just drill the 4 lug ones.
