Old 05-07-2010, 10:00 PM   #1
sil80dreamer
sil80dreamer's Avatar
sil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nicesil80dreamer is just really nice
SR SR making a screaming sound
I have a s13 redtop with stock t25, and recently it started making a sort of screaming sound when I get into boost. If i drive normal it does not make the sound, only when I hit the gas hard. So I think one of the fins is chipped, bent, or something of he sort. Can anyone confirm this, and can i be fixed without getting a new turbo? Thanks in advance.
If you bought or sold me something, please leave me some feedback here.
#/f/private-sellers/...80dreamer.html
sil80dreamer is offline   Reply With Quote
Old 05-07-2010, 10:03 PM   #2
S14DB
AFC #1
S14DB's Avatar
Sounds like a boost/vac leak.
Old 05-07-2010, 10:22 PM   #3
[email protected]
Trader Rating: (32)
R@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymoreR@ddy is not welcome here anymore
Feedback Score: 32 reviews
exhaust leak between manifold/turbo
done.
R@ddy is offline   Reply With Quote
Old 05-07-2010, 11:45 PM   #4
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
belts tight?
supreme_1 is offline   Reply With Quote
Old 05-08-2010, 12:17 AM   #5
nismo619
nismo619 is an unknown quantity at this point
sounds like your manifold to turbo gasket. is it the stock gasket or metal? if its the stock thats deff what it is. do you smell fumes more ? and it will get worse a lot worse if thats what it is. youll know cuz it will start to sound like your running open headers lol and you wont boost as much
nismo619 is offline   Reply With Quote
Old 05-08-2010, 08:10 AM   #6
jspaeth
jspaeth's Avatar
jspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfectionjspaeth is close to perfection
done.
If it sounds like a scream, I would go with either exhaust manifold, turbo--->manifold, or turbo--->elbow gasket being leaky.
I had this before and it sounded like a high pitched shreaking....
If it is more of a vibrational, metal sounding noise, it could be turbo fins hitting the walls of the housing.
J
Daily driven
jspaeth is offline   Reply With Quote
Old 05-08-2010, 08:49 AM   #7
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
maybe someone in the car is screaming when that deadly t25 spools up!
Chrischeezer is offline   Reply With Quote
Old 05-08-2010, 09:28 AM   #8
Booterzzz
Booterzzz is an unknown quantity at this point
I had this problem with my big 16g. It was an exhaust leak, it was very very loud. Either that or your turbo is about to grenade. Good luck with the fix!
Booterzzz is offline   Reply With Quote
Old 05-08-2010, 12:26 PM   #9
sil80dreamer
They are the stock gaskets, and I have noticed fumes more than I normally do.
Old 05-08-2010, 12:28 PM   #10
sil80dreamer
Haha, there is screaming, but only when they are drunk.
Old 05-08-2010, 12:32 PM   #11
sil80dreamer
Yeah it is definitely a high pitched shreak. Thanks for all your guys help. Im gonna check my gaskets before i go the expensive route.
Old 02-17-2011, 11:26 AM   #12
jons14
jons14's Avatar
jons14 is an unknown quantity at this point
I have a similar noise coming from my turbo. When hitting boost, near 5000rpm from inside the car you can hear a high pitch "zing" It still hits proper boost, and drives good. Not sure as to what it is, its currently in storage so I will try to look at it without being able to drive it. I did replace the gasket between the turbo and manifold about 5000km's ago... i dont think that it should be worn out already. Any advice would help. THanks!
jons14 is offline   Reply With Quote
Old 02-17-2011, 01:13 PM   #13
Sileighty_85
Sileighty_85's Avatar
check for Shaft play on the comprssor wheel
Usually when the turbos blow the comprssor wheel will make contact on the wall and make a buzzy screaming noise
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 02-17-2011, 05:28 PM   #14
KaminaSan
KaminaSan's Avatar
KaminaSan is an unknown quantity at this point
I want to put this as my sig.
KaminaSan is offline   Reply With Quote
sr20det, t25
