Function and form type2 S14 max height?
Sup guys.
I slapped on a isis arms suspension kit, CS tie rods, cusco sway bars, and Function and form type 2 coilovers on my S14. I used to have koni yellows on eibach sportlines. I took it in for an alignment and the drop was too low in the front so i raised the front and while i was raising the rear to match, it started to seem unsafe. As if it was running low on threads, but the rear tire is still 2 inches tucked. what is the max safe height for these Coilovers? |
![]() Join Date: Jun 2004
Trader Rating: (73)
Post a pic. If you can't get it aligned at the height you want, sounds like you need to go to a different alignment rack.
![]() Join Date: Jul 2012
![]() ![]() ![]() ![]() Feedback Score: 0 reviews
yeah take it to a different shop. i got mine done at kauffman tire because they had one of those racks that lowers flat into the ground and then you pull onto it
no such thing as too low |
So i tested out how low they can go and you can drop 2 inches past the rear diff touching the ground with the exhaust removed
So what is the point of this thread?
My SR20VET |
