![]() Join Date: Sep 2009
Hey guys,
I just ordered 555cc sti yellow sidefeed injectors, They came with no connectors... I was wondering if any of you guys know which connector would fit the sr20 stock fuel rail and also, where to get them?? Thanks P.S. I've been reading that STi 04-07 and Legaly's would fit, they're rare as snow in the desert....... ''sigh'' |
![]() Join Date: Dec 2004
Trader Rating: (58)
THe easy answer is to just splice Subaru injector clips into the nissan harness, however if you want them to be plug and play, ebay actually sells subharnesses that you can use.
IIRC you can use almost any subaru connector, even off old legacy's etc etc and they will work. They are cheap as hell, and work perfectly
