Old 08-23-2001, 12:31 PM   #1
drifterx
drifterx's Avatar
drifterx is an unknown quantity at this point
Send a message via ICQ to drifterx Send a message via AIM to drifterx
first of all, where are the stock amplifiers located....
next, if i take a few of them and amp up cheap speakers, will it work? like 2 stock amps to move a pioneer 4X6.....
i dont have any money as u can see.... i already have a Jensen amp for the front speakers, and putting in a SUB already.... so if i wanna power the rears a little better without spending another $75-100 for an amp, how can i do that?
drifterx is offline   Reply With Quote
Old 08-23-2001, 01:02 PM   #2
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Jeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond reputeJeff240sx has a reputation beyond repute
Well.. I dunno what year / trim car you have.  On my '96 SE, the stock amps are dangling below the rear deck.  If you have them, you'll see them, they are big, silver boxes.  I don't think that a 4x6 will fit in my car, as all the speakers were 6.5".  Do you already have the 4x6 installed?
Amping up cheap speakers will always work.  But they'll blow.  It's like a 400hp NOS fogger system on a '73 Pinto.  Also, when you amp cheap speakers, you will amplify the cheap sound of the speakers.
I really don't remember what ends the stock amps had or if they fit on my Polk 6.5".  I left my interior speakers un-amped.
Finally, if you wanna power your cheap rear speakers, and don't have stock amps, use the Jensen that is powering the front speakers.  The sound quality of powered fronts and not powered rears is poor.  The highs hit your ears sooner than the midbass from the rears.  Do it visa-versa, and you will get better surround sound quality.
-Jeff
Jeff240sx is offline   Reply With Quote
Old 08-23-2001, 01:21 PM   #3
drifterx
drifterx's Avatar
well my speakers r cheap but better than stock....
they can handle up to 75 or 100W
i forgot....
but a couple of stock amps should be enough....
i ahve a 89-90 model
Old 08-23-2001, 02:56 PM   #4
my240likenoother
my240likenoother is an unknown quantity at this point
Send a message via Yahoo to my240likenoother
the stock amp is the deck
so when u remove the deck you remove the amp but if u have a aftermarket deck it should be putting out about 30-40 watts that is enought for the rears
i have a amp on the fronts and the rears are running off the deck and i can hear them loud and clear over 140db's of bass
my240likenoother is offline   Reply With Quote
Old 08-23-2001, 03:08 PM   #5
drifterx
drifterx's Avatar
yeah but i dont think it is loud enough with the windows down and driving at 75 mph
also can i get it to sound better without buying another amp?
it sounds like other stock cars....
Old 08-23-2001, 05:16 PM   #6
my240likenoother
it wont sount any better intill u put some money in to some good specks the amp wont do mutch sence u can only put about 50 in to thoes specks after 50 watts they will blow over a short time
trust me i went throught 4 sets of rears
Old 08-23-2001, 06:08 PM   #7
drifterx
drifterx's Avatar
well the front ones are amped... these r not stock speakers.... the fronts sound alot better than the rears
Old 08-23-2001, 06:22 PM   #8
Guest
Posts: n/a
if u have a s-13 the amp is in the rear..... its round and very small
Old 08-23-2001, 07:05 PM   #9
96SEChick
96SEChick's Avatar
96SEChick is an unknown quantity at this point
Will am S14 amp work for an S13?  I have an extra S14 amp if it will work.
96SEChick is offline   Reply With Quote
Old 08-23-2001, 09:21 PM   #10
drifterx
drifterx's Avatar
yeah they will work but thanks anyways... they r basicly the same i think....
Old 08-23-2001, 09:41 PM   #11
Jeff240sx
I hate you too...
Jeff240sx's Avatar
Umm.. the "deck"?  The head unit?  Anyway, I don't care if you have a 180-watt tuner, claiming 45-watts a channel...  You will ONLY put out 17 rms.  a 200 watt tuner is worth close to 22 rms.
-Jeff
Old 08-24-2001, 03:30 PM   #12
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
Even that's not always true. My head unit has a claimed 180 watt max tuner, with 22 watt RMS. For the sake of making sense, only deal in the RMS numbers. Regardless, it's enough power (for me) to hear over wind noise at higher speeds. You also want to look at your speaker sensitivity. More sensitive speakers play louder with less input. As far as the factory amps go in an s13, get rid of them. All they do is take your higher wattage out of a new head unit and turn it into 5 watts for the speakers.
misnomer is offline   Reply With Quote
Old 08-24-2001, 06:09 PM   #13
transient
transient's Avatar
transient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant futuretransient has a brilliant future
Send a message via ICQ to transient Send a message via AIM to transient
There's a reason for the speaker sensitivity to be lower though. You'll often find higher quality speakers to have a lower sensitivity rating. That's because the lower the sensitivity the less work the speaker is trying to do with a certain amount of power.
transient is offline   Reply With Quote
