Old 12-09-2008, 01:17 AM   #31
stealthsr20
stealthsr20's Avatar
stealthsr20 is an unknown quantity at this point
i've got a stock sr14 bov fo sale. make me an offer! plus pipe
stealthsr20 is offline   Reply With Quote
Old 12-09-2008, 01:24 AM   #32
shytdoode
shytdoode is an unknown quantity at this point
How's the greddy rs? Same thing as thr greddy r??
shytdoode is offline   Reply With Quote
Old 12-09-2008, 07:37 AM   #33
SoSideways
SoSideways's Avatar
Uh, no.
Type-R = 47mm valve, 50mm diameter discharge port, has a HUGE diaphragm up top, and has the extra hole already drilled/tapped for a 1/8 BSPT fitting to achieve quicker response on opening the valve during lift off if you so choose to.
Type-RS = 40mm valve, has a horn on it that's supposed to give it a distinct sound (it doesn't work, I've driven around with the horn off and it sounds exactly the same) and has a much smaller diaphragm. Also does not have the provision for the lower fitting to be fitted to the valve to quicken its response.
The Type-R is WIN.
Type-RS is barely pass.
