![]() Join Date: Apr 2011
we just finished swapping my weak open diff on my s14 for a '95 j30 vlsd. it was pretty easy with no modifications except for swaping covers. now i drove for about 5 miles and when i rolled to a stop, in neutral, the rear started shaking like a mutha and so was my shift knob. it stop shaking when i put it back in first and gave it some gas. the only thing i can think of is the diff bushings that mount near the driveshaft. since i cant use the s14 ones i used the rubber washers that come off the s14 bushings. any ideas will be great before i jack up the car tomorrow again.
got it fixed. aparently the driveshaft was off balance becuase the pumpkin was sitting too high. i put about 8 or 10 washers to get it to stock height, now it works smooth with no shake at all.
![]() Last edited by desertKAdrifter; 04-21-2011 at 08:40 PM.. |
![]() Join Date: Nov 2004
Wanted to add: Avoid driving with this problem if you can. An off-balance driveshaft and/or drivetrain can destroy itself and perhaps your engine in minutes pending how bad it is.
KA-T ORG-Function over Flush
you can measure the end of the driveshaft to the car before u start. i already had mine swapped so what i did was thread the bolt until only the threads were in and then measure up how many washers i needed. i ended up using about ten on each side and made sure it was tight. i also used a locking washer on the bolt just to be safe.
| j30 diff, s14, shakes, swap, vlsd |
