Botched 350z Overfender..
I accidentally cut my fender wrong today while in the middle of an overfender install. I wasn't paying attention and I cut off both layers of the fender instead of just the top layer, and making slits in the bottom layer, folding it over, etc. Not a big deal, the only real issue is that there is a gap between the layers of fender now where dirt and moisture can collect. What should I use to fill up that gap? Or is it a better idea to weld on a new piece of metal and then make the slits, fold them over, etc..?
#2 | |
![]() Join Date: Dec 2005
What would be the best option for expanding foam? I've only used great stuff and i'm pretty sure it's flammable
![]() Join Date: Feb 2013
![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
I've cut fenders on many of cars never have used foam, not shore what u boys doing.cut, beat,weld,grind,seam seal, prime/paint/under coat. If u cut the iner short just weld a piece in. U might be able to geting away with beating it in then weld.
Weld a new strip of metal in. Use a piece of cardboard to make a template, then trace on to a piece of similar thickness sheet metal. Cut it out and install. Make sure you use weld through primer and seal the area real well.
My SR20VET |
