Old 02-10-2011, 03:12 AM   #1
R4Race
R4Race's Avatar
R4Race is an unknown quantity at this point
S15 Mazworx SR23VET
Hi fellas,
Been on this forum for a while now, but only really a reader rather than a poster. Anyway since there not that many S15 builds on this forum so I thought I might contribute. To make it easier I just copy and paste from my original member ride from NS.
Presently the car sitting there waiting for it new SR23VET engine from Mazworx, which should be arriving in late March I guess.
Hopes you guys like it and thanks for looking. Any comments and advices welcome.
ENGINE
Mazworx SR23VET (90mmx91mm Engine)
Cylinder Head
Core SR20VE P11 Cylinder Head
Supertech Dual Valve Spring, SR20VE, 123lbs on the seat, for turbo
Supertech Titanium Retainers, SR20
Supertech Nissan 6mm Exh Guide, DE/VE
Supertech Valve Guide Intake Nissan SR20DET/RB26 6 mm stem Manganese Bronze
Supertech Intake Valve Stem Seal, SR20
Supertech Exhaust Valve Stem Seal, SR20DE
Supertech Intake Valve, +1mm, SR20VE
Supertech Iconel Exhaust Valve, +2mm,SR20VE
Supertech Inner Spring Locator, 6mm Valve,SR20
Kelford Racing Cams, SR20VE, High RPM Turbo duration @ 1mm 250/256
Tomei Adjustable Cam Gears
Mazworx 1/2" Head Stud Kit w/ Dowels
Mazworx SR20DET Headgasket, 90mm Bore
Clean and R/R Oil Ports
CNC Combustion Chamber, 90mm Bore
Stage 2 Port and Polish Gasket Match, Bowl Work, Blend and Polish
Competition Valve Job, VE
Resurface Head
R/R Valve Guides
SR 1/2" Stud Machining, Head
Machine Headgasket for 1/2" Head Studs
Assemble/Shim (Solid Pivots)
Block
S13 Core Block
Darton Nissan SR20 Dry Sleeve, Double Flat
Darton Nissan SR20 Dry Sleeve, Single Flat
Oil Pump, SR20VE
Mazworx SR20 Main Stud Kit
4 Custom CP Pistons (set of 4) -- 90mm 9.0:1 VE Head
Carrillo Connecting Rods, SR20, WMC Bolts
Mazworx SR20 91mm Billet Crankshaft
ACL Race Thrust Bearing, Nissan SR20
ACL Race Rod Bearing 19mm Wide SR20DET
ACL Race Main Bearing Set, NissanSR20DET, w/ 5 Oiling Holes
Nismo Pilot Roller Bearing
ATI Super Damper, SR20 RWD
Oil Pickup, SR20
SR20VE Oil Pickup Assy
Water Pump, S13, SR20
Greddy High Capacity Oil Pan, SR20 RWD
Sleeve Install
Bore & Hone w/ Torque Plate -- 90MM
Resize Line Bore
Resurface Block & Oil Pump
Oil Groove Machining, SR20
SR 1/2" Stud Machining, Block
19mm Rod Bearing Machining
Weld Oil Pickup
Assemble Short Block
Timing Chain, SR20
Crank Key
Sprocket, Crank, SR20
Timing Chain Tensionor, SR20
Tensioner Gasket
Timing Chain Guide, Fixed, SR20
Timing Chain Guide, Adjustable, SR20
Bolt, Adjustable Chain Guide
Mazworx SR20 Bolt Kit, Fixed Timing Chain
Guide
Labor Assemble Short Block/Degree Cams
Engine Misc
Taark's VVl relocation kits + braided lines
Machined VVL solenoids and Taark's bracket
20ve CAS
Custom oil catch tank with -an fittings
Taark's oil relocation kit
Taark's PS bracket for PS pump relocation + braided lines
Relocated PS resevoir
Taark's custom water lines
Greddy pulley kit
S13 oil Dipstick
Sand blasted alternator +powder coated alternator bracket
Wrinkle red rocker cover
Nismo oil cap
Rocker Studs, Rocker Washers, Stainless Dome Nuts
INDUCTION
Hot side
Twinscroll GCG GT3076R .82 AR turbo
Twinscroll 6 boost steampipe turbo manifold (redrill to fit VE)
Twin 44mm Tial wastegates
Custom 4 inch aluminium intake pipe
Greddy air intake
Custom aluminium hot pipe (heat shield wrap)
Weld 90 degree turbo flange
Custom braided turbo oil/water lines
Earl's heat shielding sheath
20ve 7 layer metal exhaust gasket
Twinscroll turbo/manifold metal gasket
Black silicon joiner
Cold side
Mazworx VE intake manifold
Plazmaman 90mm throttle body
Taark's custom TB/manifold flange with throttle cable relocation
Custom aluminium cold pipe
-An fittings for IM
FUELLING
ID2000 fuel injectors
Complete removal of stock fuel tank setup
Custom 40ltr fuel cell with fuel sender
Holley lift pump
Twin Bosch 044 external pumps
2ltr surge tank
2 inline -an 10 AEM fuel filters
Hardlines for in cabin
Braided lines feed -an 10 return -an 8
Mazworx fuel rail modify with twin entry
Sard type RJ FPR with pressure gauge
-An fittings throughout
Custom fuel lines brackets
COOLING
Water
Koyo radiator
Ford BA radiator shroud and fans
Thermostat
Custom VE water outlet incoporating swirl pot
Custom header tank with -an fittings
Modified water inlet with -an fitting for header tank
Nismo cap
-An fittings
Custom braided lines for swirl pot/header tanks system
Air
Modify ARC intercooler
Reverse and under radiator support mounted
Custom brackets
Oil
Earl 19 rows oil cooler
Earl thermostat
Haltech oil pressure and temp sensors
Earl 13 rows PS cooler
Oil relocation kit
-An fittings and braided line throughout
ELECTRONIC
Haltech PS1000 ECU
Haltech 4 bar map sensor
Haltech engine loom
M&W pro 14 ignition
Racepak/Haltech IQ3 display Dash
AEM pencil coils
HKS EVC IV boost controller
Custom coil pack wiring
Custom alternator /starter motor wiring
Custom headlight, horn and radiator fans wiring
Relocated fuse box in cabin
Custom control switch panel
EXHAUST
Custom v-band dump/front pipe heat wrap
Custom twin screamer pipes heat wrap
Greddy Ti-R titanium exhaust
DRIVETRAIN
Stock 6-speed
ORC twin plate clutch
ORC single flywheel
Nismo clutch slave
Braided clutch line
Custom 1 piece tail shaft
Nismo 1.5 way TT pro lsd
Cusco engine mounts and Nismo gearbox mount
Brakes/Suspension
Stock s15 brake
Endless EuroX front, NA-R rear
Endless brake fluid
Removal of stock ABS system
Custom hidden hard brake lines
Zeal function XS 7k front 4k rear (used to be 9k f 7k r)
Nismo power brace
Whiteline adjustable front and rear sway bars
Whiteline subframe bushes
Cusco rear camber arms
Driftshop tension rods
Cusco front and rear strut braces
Wheels/tyres
Works XD9 bronze
18x10 +38 front
18x10 +18 rear
30mm project kics wheel spacer front
25mm H&R wheel spacer rear
Kumho KU36 265/35 front and 275/35 rear
Works light weight wheel nuts
Interior
Semi strip (AC/heater removed, removed all unnecessary wiring under dash etc)
Complete removal of stock dash cluster
Battery relocated to behind passenger seat
Custom dash cluster for IQ3 dash
Bride stradias driver seat
Bride low max seat rail,
Custom switch panel
Exterior
Wisesquare front bar
Wisesquare carbon front diffuser
Wisesquare carbon air ducts
Rmagic FD3S front/rear canards
First molding carbon rear diffuser and carbon diffuser canards
Feed FD3S style carbon sidesteps
Custom modify vented time attack style stock metal front guards
Wisesquare 50mm rear over fenders
Buddyclub carbon GT wing
Carbon bonnet
Aerocatch flush bonnet pins
GT carbon mirror
Custom front tubs
Stitch welded engine bay
Firewall gold heat shield
Respray in Honda championship white
There should be other things that I forget, but that should be all for now I will start up loading photos from time to time.
Thanx for looking
This is what it look like when I was running around doing silly stuff :silly:
Suspension
Engine
wheels
And this is what it look with some of the body parts
[attachment=279009:n101.jpg] :woot: :woot:
R4Race is offline   Reply With Quote
Old 02-10-2011, 03:21 AM   #2
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
Quality parts! Insane build! Quite sexy!
Keep us posted!
BRICKHOUSE PRODUCTS
IG @brickhouse_products
irritatedmax is offline   Reply With Quote
Old 02-10-2011, 03:26 AM   #3
ESmorz
ESmorz's Avatar
You had me until the overfenders.
*swoon*
Old 02-10-2011, 03:38 AM   #4
R4Race
R4Race's Avatar
S15 Mazworx SR23VET (Initial run in dyno video pg13)
Some pics of the car semi complete with the body parts.
Couple of the engine build!
Old 02-10-2011, 05:52 AM   #5
PoorMans180SX
PoorMans180SX's Avatar
Wow, this is serious business right here. Subscribed!
Old 02-10-2011, 06:23 AM   #6
s14freak93901
s14freak93901's Avatar
s14freak93901 can only hope to improve
nice clean work. that Maz SR is gunna be a beast.
s14freak93901 is offline   Reply With Quote
Old 02-10-2011, 06:29 AM   #7
acheron
acheron's Avatar
acheron will become famous soon enoughacheron will become famous soon enoughacheron will become famous soon enoughacheron will become famous soon enoughacheron will become famous soon enough
whats up with that gap between the front fender and door? looks a little off..
acheron is offline   Reply With Quote
Old 02-10-2011, 06:30 AM   #8
acheron
acheron's Avatar
sweet car. good work
Old 02-10-2011, 06:59 AM   #9
dmp316
dmp316 is an unknown quantity at this point
pure sex. wicked wicked. keep up the good work.
New setup how much power are you planning to make?
dmp316 is offline   Reply With Quote
Old 02-10-2011, 08:21 AM   #10
Nick_04K
Nick_04K's Avatar
Nick_04K is an unknown quantity at this point
SR23VET s15? Holly shit, this car is soo many members wet dream.
Nick_04K is offline   Reply With Quote
Old 02-10-2011, 08:29 AM   #11
racer98
racer98's Avatar
Trader Rating: (128)
racer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant futureracer98 has a brilliant future
Feedback Score: 128 reviews
Send a message via AIM to racer98 Send a message via MSN to racer98
Nice build op, best motor and head choice, you're going to like the power you will be putting down on this . What sort of clutch will you be using dual or triple ?
racer98 is offline   Reply With Quote
Old 02-10-2011, 08:49 AM   #12
tricky_ab
tricky_ab's Avatar
I've been following your build over on Silvia Aus forums for a while now. Nice to see you've made it over here!
Old 02-10-2011, 09:08 AM   #13
SlideWell
SlideWell's Avatar
this car is full of WIN, but you sir, need a better cell phone
Originally Posted by punxva View Post
i gotta fever, and the only prescription is moar hood vents
Old 02-10-2011, 09:48 AM   #14
Grenade180sx
Grenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfectionGrenade180sx is close to perfection
Send a message via AIM to Grenade180sx
awesome build. the only point i see as needing more strength is that stock gearbox. i dont think it will last to long with that amazing motor you got there!
Grenade180sx is offline   Reply With Quote
Old 02-10-2011, 09:59 AM   #15
s13boy89
s13boy89's Avatar
s13boy89 is on a distinguished road
Send a message via AIM to s13boy89
i like it beside the molded rear overfenders
I have kids running around here I dont want to use an xxr as a coffe table
s13boy89 is offline   Reply With Quote
Old 02-10-2011, 10:12 AM   #16
mewantkouki
Trader Rating: (36)
mewantkouki is making a name for him/her selfmewantkouki is making a name for him/her selfmewantkouki is making a name for him/her self
Feedback Score: 36 reviews
Is that sr really worth what it's costing you? lol
mewantkouki is offline   Reply With Quote
Old 02-10-2011, 10:29 AM   #17
NoPho4u
NoPho4u is an unknown quantity at this point
it's called wide body son...i know in bfe I don't think you guys have heard of it yet
NoPho4u is offline   Reply With Quote
Old 02-10-2011, 10:29 AM   #18
whiterps13
whiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to behold
Wow, insane build. The body is a little aggressive for my tastes but it looks dope none-the-less.
Those Zeal coilovers look beast too.
whiterps13 is offline   Reply With Quote
Old 02-10-2011, 10:33 AM   #19
h2v7
i like it in white better
Old 02-10-2011, 10:52 AM   #20
DRIFT-ELITE
DRIFT-ELITE's Avatar
DRIFT-ELITE is on the path to ruinDRIFT-ELITE is on the path to ruin
i love the time attack look your going with...all you need now are some good side skirts to help accent the car a little more and your good...
what clutch and tranny are you gonna use??..your gonna blow the stock tranny before you blow that beast of a motor your getting.
PERO POR WHY?
DRIFT-ELITE is offline   Reply With Quote
Old 02-10-2011, 11:55 AM   #21
scottie
scottie's Avatar
WOW!! Beautiful S15. Correctly built. Cosmetically it looks like a race car for the street. I like everything about it. Maybe add a front diffuser to complete the race car appeal. Thanks for sharing!!
Old 02-10-2011, 12:06 PM   #22
badicalradical
badicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of lightbadicalradical is a glorious beacon of light
Awsome build
BTW whats the pricetag on a longblock like that?
badicalradical is offline   Reply With Quote
Old 02-10-2011, 12:22 PM   #23
Drifting-pedobear
Drifting-pedobear's Avatar
Drifting-pedobear is an unknown quantity at this point
cool.
excited to see real numbers. that engine should be close to 500 horse.
watch out gleb...
RIGHTWHEELDRIVE.com
Drifting-pedobear is offline   Reply With Quote
Old 02-10-2011, 01:01 PM   #24
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
great parts list. I would have probably done alot of things different. but hey as long as your happy lol
Old 02-10-2011, 01:15 PM   #25
jesse_s13
jesse_s13's Avatar
jesse_s13 is an unknown quantity at this point
Really clean build, imma keep my on this =)
jesse_s13 is offline   Reply With Quote
Old 02-10-2011, 01:19 PM   #26
srslideways
srslideways's Avatar
srslideways is an unknown quantity at this point
subscribed
great build!
love the time attack look, i have a soft spot for time attack s15s
srslideways is offline   Reply With Quote
Old 02-10-2011, 01:23 PM   #27
ross.cottrill
ross.cottrill's Avatar
ross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant futureross.cottrill has a brilliant future
Originally Posted by badicalradical View Post
Awsome build
well mine was only a 2.2l,so he has the cost of a crank and some machining for clearance of said crank..my longblock with headswap pkg was around 13-14k..lol...lmao...cant believe i spent that much
" NEO VVL BABY FTMFW!"
Originally Posted by shagspeed
Dude if I made 500WHP on a 54C SR20DET back in 1999-2000 with old school technology .. This VET will T-BAG your RB engines
ross.cottrill is offline   Reply With Quote
Old 02-10-2011, 01:28 PM   #28
josephin510
josephin510's Avatar
josephin510 is an unknown quantity at this point
Those rear shots look sick. Subscribed.
Trade my Rb25 for some wheels.
Buy my Sc300.
josephin510 is offline   Reply With Quote
Old 02-10-2011, 01:36 PM   #29
KansaiDrifter
KansaiDrifter's Avatar
KansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud ofKansaiDrifter has much to be proud of
Beautiful S15, man how I want one! One of these days lol.
Can't wait to see the dyno sheet of the sr23vet, such a great/efficient setup.
KansaiDrifter is offline   Reply With Quote
Old 02-10-2011, 01:42 PM   #30
R4Race
R4Race's Avatar
Thanx guys for your kind comments!
It for venting air out of the front wheel archs. It look abit odd becoz it actually metal guards that been modified.
The rear fenders were untapped at the rear to again allow air from the rear arches to escape.
For track will probably be between 250-300rwkw until I learn to drive it properly. But once the engine run in, I will see what I can get out of this motor with the current turbo combo.
Will most likely running a twin, currently running ORC 709d
QUOTE=DRIFT-ELITE;3873929]i love the time attack look your going with...all you need now are some good side skirts to help accent the car a little more and your good...
what clutch and tranny are you gonna use??..your gonna blow the stock tranny before you blow that beast of a motor your getting.[/QUOTE]
Yeah I'm just using it for running in the engine, if it last for longer than that then it a bonus. Will be looking at either PPG gearset or Hollinger in the long run.
It better be!! I know I could have taken the usual root ie 2JZ RB25/26/30, or even the LS series but then where the fun in that. Plus in theory this engine should get me what I'm looking for.
Thanx mate, not many ppl know about zeal!
Thanx mate. It will get a front splitter when it get to track.
Awsome build
Just a few pennies. Every engine is different so you better of getting a quote from Mazworx.
Originally Posted by Drifting-pedobear View Post
cool.
watch out gleb...
500rwhp should be a realistic no. to reach.
