ISIS 3871 Turbo
See 2nd post for pictures
Used for about 2000 miles. No shaft play/smoking or any funny business. Will come with the WG actuator. You can use it on any T25/T28 Flanged setup. Went with a smaller turbo. Just pulled it off my running KA-T setup about a week ago. Any questions or additional pictures, PM me. SOLD SOLD SOLD Last edited by unreal-; 12-23-2013 at 10:44 AM.. Reason: removed old pictures of turbo. Turbo actually for sale is below. |
bump!
updated: took some better picture of the front of the turbo and fixed the flash issue i was having before. ![]() ![]() ![]() ![]() Last edited by unreal-; 12-09-2013 at 01:01 AM.. Reason: new front turbo picture |
The first picture of the hot side shows the wastegate flap white with super clean blades and 4 studs, second pic of the hot side shows the wastegate charred with black blades and there are only 2 studs LOL. Stealing pics much? Or is the first photo not recent?
#6 | ||
PRICE DROP!!!! turbo is now 300 shipped! |
#10 | ||
The turbo is pretty good. At the low boost levels that i was running it tended to creep, but if you run more than 12psi or so i do not think it would be a problem. I guess my setup flows more than others lol. Its a high flowing turbo and if you run lower boost levels you might need to port the wastegate hole or convert to external. It hits really hard once 4,000 comes along (on my KA) and is surprisingly easy to drive without getting into boost. Besides that it spools pretty quick for a journal bearing and pulls to redline like a mofo! ![]() Quote:
