2 sway bars welded together
Dont flame, just give me some friggen thoughts on this shit. Since Im only after a beefier rear sway bar, and money doesnt grow on trees, I was thinking this; Get another rear sway from the junkyard and either weld it under the stock one, or beside it. I would trim it so it sat nice and snug up agains the other one, and just stick weld the bitches together. Stiffen up I would think?
thoughts........... |
![]() Join Date: Aug 2003
it would work... but you would be welding two cylindrical bars together, it wouldn't sit very nice.
just get aftermarket if you want one.
Petition Nissan to Make the IDx on http://IDxClub.co ! |
![]() Join Date: Jan 2002
![]() ![]() ![]() Feedback Score: 1 reviews
why not just run longer bolts through the mounts and mount 2 to both the "D" mounts and the end links
that would give them the freedom to add stiffness, but not bind in their travels either way if you stack em, you'll take an inch or so off of ground clearance right there...
92 vert - KADE + VH41 + GM MA5 = too many parts in the garage 95 base - retired |
UUUUUUGGGGGGGGGHHHHHHHHH.
If you want more stiffness and you're too cheap for rear bars just drill a new hole on the sway. Less lever arm on the bar = more roll stiffness. If you want more stiffness than that you can take a peice of 1/4th ish sheet metal and weld it down the length of the bar inbetween the links. Thats less ghetto than taping two bars together and will get you more stiffness. |
![]() Join Date: Apr 2003
Try to visualize how a swaybar works, and you'll see why you shouldn't do this.
They work by twisting, if you stack two of them together, then one of them is going to twist and the other is going to bend, or you will effectively lock both bars, turning your rear suspension into a life axle.
Jason '95 240sx SE |
Alright, so one on top of the other is out of the question. Side by side then. Do what now with the drilling Mcrussslepants?? I think Ill try it out, wont cost me anything....so why not? Thanks for input.
![]() Join Date: Oct 2004
thats the SAME THING
high performance driveway photography zenki s14---v8 fc rx7 my crappy flickr page (drift cars whoo) |
#13 | |
I have one. Made a lot of difference. It was $25 + shipping. |
#19 |
hoooorah.....until the heat isue was mentioned, I was gonna do it...cause it wouldnt cost me shiat! But yea, thats a valid point..... but seeing as I have like 8 sway bars kicking about in the neighborhood, I might as well still give it a shot anyway.
Best Idea Ever. |
#21 | |
Well, fine. Go do it. And then come back here and tell us how it went. |
#22 | |
![]() Join Date: Jun 2005
Go cut your springs too for UBAR CHEAP DROP! |
#23 |
Admin Asshole
![]() Join Date: Mar 2002
If you aren't going to listen to logic when you ask for opinions, then don't bother posting anymore questions, please.
"Speak softly,..." -Pres. Teddy Roosevelt "Be polite, be professional, ..." -Gen. James Mattis |
#24 | |
No more nissan.
![]() Join Date: Jan 2003
If you have 8 sway bars.. SELL THEM AND BUY A REAL ONE YOU CHEAP BASTARD!
#25 | |
#26 | |
#28 |
youre a moron...do it
www.ohiodrifting.com |
#29 |
i think it would produce best results if he zip ties them together, that way he might even be able to do 3 sway bars.
Watch speed channel 12/9 @7.30PM for drifting at HIN! [email protected] IF you bought stuff from me write me a review HERE ||VEXMOTORSPORTS || DMAX-USA || RPS CLUTCH || BAB AUTOBODY|| |
