Old 05-07-2010, 06:23 PM   #1
silentstyle1
silentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nicesilentstyle1 is just really nice
Send a message via AIM to silentstyle1
Brakes not stopping...
I checked and couldnt seem to find this problem, i've found other similar problems, but nothing exactly the same as this, so I figured I'd ask.
Ok so the s14 im going to buy just had a z32 brake conversion done on the front. brand new rotors calipers and pads, stock s14 BMC and agency power SS lines. now the problem is that the car has absolutely no braking force... the pedal goes straight to the floor, but if I pump it before coming to a stop it get firm, but then it goes right back to going to the floor. We bled all four brakes for about an hour and there was no change, clear fluid and there are no leaks anywhere.
can somebody help, cause i'm really confused.
well im sitting in my car in the garage wathcing a movie on my mac thats sitting on the hood eating homemade french toast on 18s gettt some
Nice to know I've got a 30k VA transformer all to myself with 100A 3-phase if I want to start building Cybertron or something in here.
silentstyle1 is offline   Reply With Quote
Old 05-07-2010, 06:24 PM   #2
I LUV MY S13
I LUV MY S13's Avatar
Trader Rating: (35)
Feedback Score: 35 reviews
booster?..
-Jorge
Old 05-07-2010, 06:32 PM   #3
ILL S13
ILL S13's Avatar
ILL S13 is an unknown quantity at this point
Originally Posted by I LUV MY S13 View Post
booster?..
just like he said same thing happened to me 4 months ago first the booster took a crap then the bmc.
ILL S13 is offline   Reply With Quote
Old 05-07-2010, 06:38 PM   #4
silentstyle1
I was thinking that, but the kid im getting the car from put a stock s14 booster and bmc on, why he choose that instead of just going for the z32 idk...
Old 05-07-2010, 07:01 PM   #5
Sileighty_85
Sileighty_85's Avatar
Booster will make the Pedal STIFF
OP make sure the bleeder valve are on the tops of the calipers, Its a common mistake
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 05-07-2010, 07:04 PM   #6
silentstyle1
I thought that too, but they are all on the top.
Old 05-07-2010, 07:08 PM   #7
Sileighty_85
did you bench bleed the master cylinder?
後輪駆動車1番
1986 SR86 - 200ish
Old 05-07-2010, 07:11 PM   #8
silentstyle1
I dont know if he did that yet. Probably not. And I really dont know whats involved in doing that, but I will search to find out how.
If there are any more possible reasons, please continue to post them.
Thanks for everything so far. I knew there was a reason i loved this site.
Old 05-07-2010, 07:17 PM   #9
Sileighty_85
if he didnt bench bleed it then thats his problem
後輪駆動車1番
1986 SR86 - 200ish
Old 05-07-2010, 07:23 PM   #10
silentstyle1
Ok I will look into that, when I get the car home tomorrow.
So it wouldn't be the fact that it doesn't have a Z32 bmc?
Old 05-07-2010, 08:05 PM   #11
Sileighty_85
Nope I have a Full Z32 Setup on my S13 using the Z31 BMC (S13 Auto BMC)
後輪駆動車1番
1986 SR86 - 200ish
Old 05-07-2010, 08:07 PM   #12
silentstyle1
Ok, thanks for the help. I will bench bleed it when I get it home
Old 05-07-2010, 08:14 PM   #13
lazysk8er2
lazysk8er2's Avatar
lazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud oflazysk8er2 has much to be proud of
yea also check the seals on the calipers they could be leaking as well front and rear...had that problem couldnt tell my driver side rear caliper was leaking until i took the brakes off and pushed on the seal.
Well i have a 95 240 and i like my cars low... But my parents don't like my wheels tilted
________________________________
lazysk8er2 is offline   Reply With Quote
Old 05-07-2010, 08:58 PM   #14
silentstyle1
I'll check those as well, if anything it would be the rears, cause the fronts are brand new
Old 05-08-2010, 04:48 PM   #15
silentstyle1
Ok, so I picked the car up today. and as soon as I got it home I bled the brakes and booster and the car now stops, pedals a little spongy but it stops good. i guess the kid didn't bleed it right or something. Thanks to everybody who gave me some input, I appreciate it.
Old 05-08-2010, 05:32 PM   #16
Sileighty_85
Booster? or Master Cylinder?
Did you remove the MC to bench bleed it?
後輪駆動車1番
1986 SR86 - 200ish
Old 05-09-2010, 07:03 AM   #17
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Bleed that shit some more, all 4 corners. Start wit the furthest corner from the mastercylinder and work your way to the closest one up front.
Times like this, I love the Hobby Shop for having a vacuum pump...makes bleeding brakelines a 1 man job that takes no more than 10 mins to do all for if its on a car lift.
CLICK HERE!!!
Old 05-11-2010, 06:35 AM   #18
silentstyle1
No it wasnt the MC or the booster. He just didnt bleed them correctly, I bled it a little when I was at his house before i picked it up, and then I went to autozone and bled all four corners, the way that fliprayzin just said, car stopped just fine.
pedal is still a bit spongy but nothing horrible, I have a new mc coming in anyway just to be safe.
