![]() Join Date: Apr 2012
Trader Rating: (62)
![]() Feedback Score: 62 reviews
KADE-T PartOut
I've decided to Partout out my Setup
Prices Do not Include Shipping Some item Are Obo I'm in no rush to sell any of this. -Peakboost T3 Manifold external WG 2 bolt (38mm) $550 -Turbonetics Evolution WG 2 Bolt (38mm) 9lbs Spring with Custom Dump Pipe $150 -Garret 60-1 Stage 3 turbine 70.A/R 64.Ex (no shaft) less then 8k comes w/ 3in custom Down Pipe $600 -Pauter Rods used in perfect condition (Beffy) + JE Custom Pistons .20 Over 89.5MM 8.5 Comp (SOLD) -Fully built head (SOLD) BC stage 2 cams BC DvS BC titanium retainers BC oversize valves ex & in New Valve seals -AEM EMS V2 Like New With Cas Disk $ (SOLD) -AEM Fuel Rail (SOLD) -Godspeed intercooler in good shape with piping for S14 KA (SOLD) -ARP head studs $50 -JWT Ajustable cam gears (SOLD) -JWT S1 Cams $(SOLD) -Stock SR20 Injectors in Rail $50 -ID 1000cc injec (SOLD) -Fidanza Aluminum Flywheel $250 or $400 with clutch -ACT Clutch $200 -Z32 Maf $40 -B&M ShortShifter $150 -KA Transmission Shifts like butter $250 (Pending sale) -Nismo motor mounts & tranny/M $250 -S14 Climate Control $35 -S14 front & rear seats $230 -T25/T28 HKS actuator Head Only $70 -T25 Turbo Outlet $10 -S14 5 Speed Non Abs Drive shaft $80 -Aem digital boost gauge + Harness No Sensor $50 -Nrg 330MM woodgrain wheel (SOLD) -5 Lug Swap $300 -Zenki tail lights $50 -z32 Front Brake 30mm slotted rotors/ ss lines $250 -Also Parting out 96 S14 All parts are located in Pico Rivera C.A Last edited by Rb26kouki; 10-25-2013 at 09:18 PM.. Reason: Updated pricing |
Trader Rating: (62)
Valve train has about 800-900 miles when removed then head was taken to shop to clean, everything was disassemble for inspection & installed New Super-tech Valve Seals 0 miles since then
