Mazworx Engine Dress Up Sale! 9/26/16-10/03/16
Hello Zilvia! To make up for our absence on Zilvia we've decided to go ahead and offer some items with Zilvia discounts! All items listed will be offered with free standard shipping to U.S 48 Just use the discount code: ZilviaFreeShipping You can also order via phone (407-281-1223) or email ([email protected]) Mazworx SR20 Valve Cover Hardware Kit $49.99 The Mazworx SR20 Valve Cover Hardware Kit is a 100% designed and manufactured in house kit that utilizes a custom billet aluminum washer with stainless steel allen head hardware that ensures a quality finish for the lifetime of your engine. *Colored options will soon be available based on consumer demand Mazworx SR20/KA Exhaust Studs Kit $39.99 Tired of snapping your old rusty OEM exhaust studs? Our stud kit completely replaces your old hardware for the exhaust manifold on your SR20 or KA engine. Mazworx SR20 Freeze and Oil Port Plug Kit $36.45 Rebuilding or updating your engine? The Mazworx Freeze and Oil Port Plug Kit replaces all of the misc plugs on your SR engine, this is a standard procedure on any block that we build and ensure no leaks or stripped plugs on your new block. *All BSPT threads must be re-tapped to corresponding NPT thread pitch and size.
Contact: [email protected]; 407-281-1223 +25 |
That's why we've started selling the kits! Parts shouldn't have to be impossible to find.
![]() Join Date: Oct 2006
Trader Rating: (81)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 81 reviews
are the valve cover washers designed to work with the OEM rubber inserts or are those rubber pieces not required with the Mazworx setup?
Sorry for the late reply, we've been closed due to the hurricane. This kit does not use the factory rubber washers. It's a 1 piece washer designed to be as simple as possible due to the frustration associated with the factory washers that split apart.
Thank you! Also thank you to the rest of this community who helped the first batch of the kit run out in 2 weeks! We're currently running a new batch that will now be available in 3 colors, raw aluminum, black, and purple!
| mazworx, sale, sr20, sr20det, studs |
