Sr20 maf doesn't change idle when unplugged an smell of fuel really bad when idles
I unplugg the maf stock sr one an idle doesn't change that means its bad right? An there a very bad smell of gas fumes is this due to the maf? First ever sr swap an oh yea this maf is located on the coldside intercooler pipe
![]() Join Date: Mar 2007
Trader Rating: (31)
No need to Do another thread.
unplugged maf should Kill the car or make it run Horrible. At least Mine did and My car has a similar issue but under load it just runs real LEAN. Sounds like a Bad MAF.Otherwise TPS would cause a Rough run. See Tech section - Ditch Cold side maf - other guy having the same problem.
z-tERty-2 |
I just went through the same kind of issue actually, if not worse haha. Maybe you can get some pointers from my thread here. Best of luck there man.
#/f/engine-tech/4268...rt-random.html |
