09-27-2009, 09:13 PM | #1 |
Help me id these plugs!
hey guys, I'm trying to attempt a wire tuck, but when i started to ID the plugs that i needed to extend i started noticing plugs that I didn't label before pulling it into the cabin =/
Trying to figure it out, but the service manuals not helping to much. Trying to see if anyone on here knows what they are off the top of their heads. DRIVER SIDE FRONT FUSE BOX http://i24.photobucket.com/albums/c6...t/fusebox2.jpg found this close to my fuse box when i got my car with a sr20 swap in it. it was zip tied together already. looks like a MAF connector? IGNITOR CHIP http://i24.photobucket.com/albums/c6...ot/ignitor.jpg i know that's the ignitor chip, but what are the 2 sensors that are next to it? looks like a boost solenoid? and the other looks like a EVAP sensor? PASSENGER SIDE FUSE BOX AREA http://i24.photobucket.com/albums/c6...sidfusebox.jpg I know 1 and 2 goes to the engine harness, but not sure what 3 and 4 goes to. PASSENGER SIDE AREA http://i24.photobucket.com/albums/c6...rsidefront.jpg this is where most of the plugs that I'm not sure of. i THINK 2 and 3 are for the windshield wiper fluid motor, but that was removed by the previous owner and those plugs were just dangling there. 5 is a relay to something.. and the rest of them not really sure. I will be checking the FSM again and try to figure out most of them, but the previous owner did a real hack job =/ any help will be greatly appreciated thanks guys. |
09-27-2009, 10:15 PM | #2 |
Picture #1
1. Not sure what it is, but it's not needed. 2. I believe that is the PS Switch plug. MAFs are usually have 3 little connectors in them. Picture #2 1. Boost Solenoid 2. EGR Sensor 3. Igniter If I figure out anymore I'll post them up. |
09-28-2009, 10:16 PM | #5 |
Wire colors would help, especially since you can match it to the FSM that way.
Picture #1 is the AIV and A/C compressor. Picture #2 is as discussed, boost solenoid and control valve. Picture #3 is lower harness, alternator, starter, and A/C drier. Picture #4 is starter relay, wiper washer motor, few other things. Hard to tell with those pics. The FSM has a layout of all the plugs and locations. But you do have to read it a little.
