![]() Join Date: Dec 2007
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
translated s14 jdm fuse panels into english
Seeing that theres only a translated version for s13's i got tired of not knowing which fuses where which so i decided to try and translate the ones for s14.
and no, theyre not on the same place as the usdm ones, so using a usdm fuse cover is futile ![]() disclaimer: i am human, thus i couldve made a mistake so use at your own risk. the black fuse cover on the left is a jdm one, to it's right is the translated english one. *note: on the left picture where it says NISSAN, if you look to the top right corner it says 65F00, which is different from the bottom next example. *note: on the left picture where it says NISSAN, if you look to the top right corner it says 66F00, which is different from the top previous example. also, there were 3 fuses i couldn't translate, so if someone knows what they are, please post'em ![]() also, whenever i can get my hands on a jdm engine fuse cover for s14 to translate, ill post it up as well.
taking corners just as good as a drunken rhino..
![]() Join Date: Dec 2006
Right
First one says "Rear Wiper" Second one says like "Electronic Parts" Third one says same "Electronic Parts" Quote:
Second and Third again says "Electronic Parts" Not sure WTF Electronic Parts means....
Trader Rating: (44)
does anyone have an s14 engine fuse box cover? is it the same as above?
and to the guy on top, why does yours say 80F00?
