www.projectendlessmotorsports.com Become a customer at Project Endless Motorsports and you will receive a 10% off coupon for your next purchase through our website! Project Endless Motorsports is proud to present ISC Suspension to Zilvia members! Great entry level coilover at a great cost! Please PM or POST for special pricing! Please provide Year, Make, Model of application! Many applications available! S13/S14/S15/R32/R33/R34/300zx/350z/G35 & MORE! 32 Step Damper Adjustable Precise control damp valve Operates smoothly on all road surfaces Expansion/Suppression of shock adjustment Pillow-ball Upper-mount Adjustable camber allows more/less on road track for all conditions Piston Rod Design High rigidity steel piston rods Meets with race/sport standards Sports Spring Made from high quality SAE9254 steel Tested over 500,000 times on compression inspection with less than 5% deformation. Choose from Street Comfort, Street/Sport or Track/Race (spring rates vary depending on application) Ride Height Adjustable Full length height adjustable Bound adjustable with separate spring locks High quality T6061 aluminum alloy used for all adjustment locks to provide a lightweight design that holds spring and vehicle down force Aluminum Bracket Made from T6061 aluminum alloy by organic shaping to lighten weight and increase handling performance Specifically anodized surface to prevent inside corrosion and surface rust On various models camber can also be adjusted via the bracket as well as the camber tops Single Cylinder Design Larger cylinder and piston design to advance driving stability and dexterity What is the adjustment range with these coilovers? We offer the best coilover for the money hands down! Each coilover features 32-way adjustable dampening, adjustable camber, and adjustable height (3″ range) What is the warranty on ISC Coilovers? ISC offers a full 1 year warranty from any leaking or manufacturing defects. If leaking or a defect is decided ISC will replace the needed part of the coilover that is damaged for you at no cost. Email us for a warranty claim and we would be happy to assist you. If your coilover needs replacing after warranty is expired we offer our customers replacement units at a discounted rate, and do rebuilds for 65.00 each. We strive to have one of the most supportive warranties in the industry for coilovers and suspension parts. All rebuilds are done in house here in our USA facility. All PA residents subject to 6% sales tax! |
| adjustable, coilover, isc suspension, more low, suspension |
