| Europe A place for our cousins from across the pond |
The blow off valve issue
Hey guys, sooo I've bought a 200sx (eurospec) s14 that used to run on 24psi of boost, but the blow off valve, atleast according to the internet, is rated for 26psi. Sooo long story short, the car has still some major compressor surge sounds. I barely use full throttle because I use the car on the street. What kind of psi blow off valve spring would you guys suggest?
