A/C wiring for a S14 SR in a S13?
I have tried searching with no luck but I was trying to see if this is correct from what I've found in the FSMs. I have pin 25 (green/yellow) from F1 (s14 interior plug) going to green/yellow on F1 (s13 interior plug) then extended to green/yellow on F9 (s13 harness under the hood by the battery) for the relay. For the thermal control amp (AC switch) I have pin 17 (red) from F1 (s14 interior plug) to the blue/green on F1 (s13 interior plug) then extended to blue/green on F9 (s13 harness under the hood by the battery). Is this correct? I was just looking for verification from anybody that may be able to help. Thanks!
![]() Join Date: Jan 2007
run the blue/green stripe on your s13's dash plug behind the glove box to your green/yellow on your s13's brownish/red plug on the passenger side fender where the battery goes
Dave =] |
juls it'd probably be the easiest thing to use the red top sr compressor and bracket and get the ends of the high and low pressure hoses fabricated. gl
Dave =] |
