Low Pressure PS Return Line S13/S14
I have a quick question!
The low press. power steering return line on my s14 broke just last night. Its the aluminum pipe that comes out of the rack, loops around to the passenger's side hugging the subframe and then returns to the reservoir. Does anyone know if the S13 and S14 low pressure lines will interchange? Thanks! Edit: found a picture of the specific line
S14 240SX aka "The Dirty S14" fizzerkart.com/s14.html |
![]() Join Date: Dec 2002
That's not a low pressure line, it's a cooling line. They're similar enough to adapt, you may need to trim the hoses a bit and swap brackets to secure it.
Excellent, thank you.
