95 240sx 5 speed swap problems
in the process of doing a 5 speed swap. first off its a 95 240sx se. was an automatic. i want the car to be as close to stock 5 speed as possible. i have all of the stock 95 manual parts. the 5 speed engine harness and transmission harness. if im using the 2 manual harness's do i still have to jump wires? also will all of the plugs plug and play scence i used manual harness's? ill start with those questions. thanks
