| Media Forum / Pictures / Videos Forum dedicated to media, such as pictures and videos. |
S2000 F20C powered AE86 Corolla dyno!!!
This is high compression built F20C that i built and swapped into my buddies AE86 corolla. The car is running on the stock ecu. Went rich as hell when Vtec hit running between 10.5-11:1 above 6k rpms.
Made 215rwhp, 145rwtq. Not too bad at all. We are hoping for 245-255whp after the AEM standalone goes in here very very soon. It can definetly benifit from some added timing up top and get the a/f where it should be. The shop owner said he hasnt seen an s2000 motor make over 200whp on the older model dynojet that it was dynod on. So that was pretty satisfying as well to know. Here is the vid: YouTube - ae86 f20c untuned 2nd pull at motor mayhem |
240 crank hp stock. Again they usually dyno 214whp or so stock, but the shop owner of where he dynod said that no s2k has dynod over 200whp on the older model dyno jet. So i can safely assume that his dyno is reading a bit low.
On a new dyno jet its probably making 230whp or so. He will get this motor to 260whp in the near future with the new intake mani and aem to fine tune it. |
![]() Join Date: Apr 2007
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 8 reviews
first a f20c powered s13
then a f20c powered EG6 and now a f20c powered ae86.......
www.teamirrational.wordpress.com |
