Old 10-30-2012, 11:07 PM   #1
rob_240
rob_240 is a jewel in the roughrob_240 is a jewel in the roughrob_240 is a jewel in the roughrob_240 is a jewel in the roughrob_240 is a jewel in the roughrob_240 is a jewel in the roughrob_240 is a jewel in the rough
red top sr20 striped head bolts
has anyone came across this issue? im stumped as to removing this. heard a of a easy out tool to take it out but dont think this a good application for this and trying to drill it and pull it out is risky. any info, help, or a shop that can help with this is appreciative in the OC area thank.
rob_240 is offline   Reply With Quote
Old 10-31-2012, 02:10 PM   #2
Frank_Jaeger
Frank_Jaeger is an unknown quantity at this point
I would drill and tap for a left-hand threaded bolt, personally. Don't know if there're better alternatives.
Frank_Jaeger is offline   Reply With Quote
Old 10-31-2012, 02:12 PM   #3
Sileighty_85
Sileighty_85's Avatar
why are you trying to remove that?
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-31-2012, 02:19 PM   #4
1slicktwo4oh
Trader Rating: (45)
1slicktwo4oh is an unknown quantity at this point
Feedback Score: 45 reviews
Im w/ frankg ...Drill and tap L hand thread..ise a center drill first, then follow w/ appropriate drill and tap..u need a lot of holding power, so a extractor would not do the job
1slicktwo4oh is offline   Reply With Quote
Old 10-31-2012, 02:57 PM   #5
91ka24
91ka24's Avatar
91ka24 is an unknown quantity at this point
That is not a "head bolt" that holds the head to the block.
91ka24 is offline   Reply With Quote
Old 10-31-2012, 10:39 PM   #6
ShadowMan
ShadowMan's Avatar
ShadowMan is an unknown quantity at this point
^agreed. Head bolts are located under the cams. I've never tried to remove these as I never had a reason to. But definitely not holding head to the block.
in any situation....thou shalt blaze
ShadowMan is offline   Reply With Quote
Old 10-31-2012, 10:46 PM   #7
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Wtf r u trying to take that out for...on a few of the heads we went through to the gill we usually bake the heads to pull em but you really don't need to pull that
Memberofthe600hpkaclub is offline   Reply With Quote
Old 11-01-2012, 04:41 AM   #8
TheWolf
TheWolf's Avatar
that is a casting plug. 99 out of 100 times, they don't come out. if it does, it will need heat and other encouragement. No easy out is going to work there. Keep messing with it and you could have a head that's no good.
Eye on the Prize
Old 11-01-2012, 05:32 AM   #9
ForeignMuscle
ForeignMuscle is an unknown quantity at this point
Lol, I would edit this or something bud. You are going to be eaten alive..
ForeignMuscle is offline   Reply With Quote
Old 11-01-2012, 12:41 PM   #10
rob_240
First time taking apart a sr20 head. Tried lolking this up for awhile and couldnt find anu info on it so i resortrd to here. everyone has there clueless or stumped moments. Assumed this was holding the head to the block. Now knowing this is a casting plug and has no purpose for what I'm doing ill leave it alone. Thanks.
Old 11-01-2012, 06:06 PM   #11
GroundPerformance
GroundPerformance's Avatar
Trader Rating: (44)
GroundPerformance is an unknown quantity at this point
Feedback Score: 44 reviews
You should prolly get some help locally in building your engine.
SoCal KA24DET/KA24ET Owners
<< Join the FB Group >>
GroundPerformance is offline   Reply With Quote
Old 11-01-2012, 06:53 PM   #12
rob_240
im pretty conifident on my abilities to disassemble and re-assemble the motor have things marked out. as far as ft. pounds of torque and torque order ill have help on that. and if i have problems have this beauty of a site to help me, want to be able to do it all myself self pride i guess.
Old 11-01-2012, 07:39 PM   #13
Davidna2fi
Trader Rating: (18)
Davidna2fi is an unknown quantity at this point
Feedback Score: 18 reviews
Don't forget the FOUR 10mm bolts that are around the head on the corners of the exhaust side and also the 2 bolts on the front cover as well. Head should lift right off. Never had an issue with a head stuck.
Davidna2fi is offline   Reply With Quote
