S13 Headlights turn on but stay closed
What's up fellas I've been having a problem with my headlights for a while now. I've googled and searched but it seems the common problem is people are having issues with the headlights not closing or open when they should be closing.
After turning the headlights on via the switch, the headlights turn on but the pop ups stay closed. Correct me if I'm wrong but usually the headlights don't turn on until they are in the up position.
The pop ups will come up once I pull the switch back as if I'm flashing someone my high beams. They close perfectly normal.
I'm not too familiar with how exactly the headlights work as far as what signals the motor to open and how it knows when it's open etc. I checked related fuses and relays but came up with nothing. Any help would be appreciated.
