Old 05-30-2009, 12:27 AM   #1
ImPLiCiTS14
ImPLiCiTS14 is an unknown quantity at this point
Send a message via AIM to ImPLiCiTS14
s14 rear clunking after lowering springs installed?
tonight i installed some eibach sport lines on my s14 and for some strange reason the rear is clunking bad like its going to fall off. The wierd thing is i tightened everything even with a air gun any suggestions?
ImPLiCiTS14 is offline   Reply With Quote
Old 05-30-2009, 04:12 AM   #2
upsdude
upsdude's Avatar
Trader Rating: (46)
upsdude is an unknown quantity at this point
Feedback Score: 46 reviews
s14
if it's coming from the rear then check your subframe bushings. seems to be a common ailment to s14's. my rear subframe clunks if i brake too hard or accelerate too suddenly. already ordered some new energy bushings from www.frsport.com but they're backordered . good luck.
upsdude is offline   Reply With Quote
Old 05-30-2009, 06:40 AM   #3
ImPLiCiTS14
but this happened immediately after installing the sportlines.
Old 05-30-2009, 10:31 AM   #4
clv5045
clv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymoreclv5045 is not welcome here anymore
it problem isnt anything serious that can stop you from driving it, it's just annoying. when you lowered it you probably brought something that was already loose close enough to something else to knock around, i have no idea what exactly it could be, but i would just check everything that is around the axle like sway arm, torsion bars, etc to see if any of them are loose, broken, or have bad bushings
91 240 cpe w/ sr SOLD
96 240 w/ sr
clv5045 is offline   Reply With Quote
Old 05-30-2009, 01:23 PM   #5
Kiwi
Kiwi is an unknown quantity at this point
actually, subframe bushings CAN be a real problem. eventually it can bend the studs where the bushings go in.
implicit, maybe you're bottoming out, that can cause some sort of a clunking. anyway, i'd still check the subframe bushings just in case
i don't know how low your car is now so that would be what i suspect
Kiwi is offline   Reply With Quote
Old 05-30-2009, 02:37 PM   #6
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
what da fuck!
Installed with air tools...rear shocks on an S14......14lbs/ft of torque.
Bigsyke is offline   Reply With Quote
Old 05-30-2009, 05:01 PM   #7
ImPLiCiTS14
the sound is very very loud tho like the suspension isn't tight at all. i didnt even need spring compressors to install rear.
Old 05-30-2009, 05:27 PM   #8
The Chad
The Chad's Avatar
The Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really niceThe Chad is just really nice
Time and Time again...almost allways comes back to subframe bushings. Same thing happened to me after i lowered my car and install new shocks. I head the phantom clunk! Searched around and found the problem...the subframe bushings on S14's are notorious for wearing down over time.
You can either buy NEW bushings and pull your subframe (EEEK!)
Or simply buy some $30 spacers/inserts avail through many parts distributors online for S14's.
I just installed the Aluminum inserts and Presto!...No more clunk! Took no more than 20 mins too Much easier than pulling the subfram and torching out bushings/hammering in new ones.
The Chad is offline   Reply With Quote
Old 05-30-2009, 05:48 PM   #9
Drft_S14
Drft_S14's Avatar
Drft_S14 is making his/her stupidity well-knownDrft_S14 is making his/her stupidity well-knownDrft_S14 is making his/her stupidity well-known
just make sure ur springs are lined up right with the top hat, sometimes if its not it tends to make that annoying noise, goodluck
I never narc'd on nobody
Drft_S14 is offline   Reply With Quote
Old 05-30-2009, 06:35 PM   #10
Bigsyke
Bigsyke's Avatar
inserts made my clunk ALOT worse.
Old 06-01-2009, 03:56 PM   #11
ImPLiCiTS14
i took a look today and its seems there is a big gap between the tightened center nut/thread and the tophat even thought its all the way down to the end of the thread.
Old 06-01-2009, 06:09 PM   #12
s14_mike
s14_mike will become famous soon enoughs14_mike will become famous soon enoughs14_mike will become famous soon enoughs14_mike will become famous soon enoughs14_mike will become famous soon enough
you need to hold the center shaft off the shock at the top not where the shaft goes up and down(there should be a little rectangular peace to hold) with a pair of channel locks or vice grips and then tighten then nut with a wrench. just because you used air tools to tighten the nut down to hold down the top hat doesn't mean that you bottomed out the nut. The shaft could have been spinning the whole time you were trying to tighten down the nut with the gun.
s14_mike is offline   Reply With Quote
Old 06-01-2009, 06:15 PM   #13
Bigsyke
Bigsyke's Avatar
alan wrench usually, or use a box wrench that fits snug
Old 06-01-2009, 06:23 PM   #14
ImPLiCiTS14
i had used a pair of vice grips to keep it from moving -=i know dumb move=-
Old 06-01-2009, 06:40 PM   #15
Bigsyke
Bigsyke's Avatar
^^I did that on a honda, the alan port collapsed, thus I had to use the piston shaft, which destroyed the shock.
