![]() Join Date: Jan 2004
Trader Rating: (115)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 115 reviews
Parting out 4 S13's and 1 S14 KA & SR Parts!
Updated the list 2-13-14 (415) 724-0675 Cars S13.4 240sx truck rolling shell. The truck comes with a bunch of fab work already complete as well as bodywork. I can deliver the shell if needed for extra. 90 240sx hatch 89 s10 rear cab section completely Rhinolined 97 Kouki Fiberglass Conversion front end w multi vent hood Fiberglass doors Fiberglass 30mm overs Mustang Gt rear spoiler Formula Drift spec roll cage Rear bash/jacking bar and front lower bumper protector bar. Quick disconnect Tube Front Full Aggressive Body kit Formula D approved fire suppression system Battery Box The car will come with stock suspension and wheels. No motor or transmission. $3500 OBO (accepting trade offers, NOT PARTING OUT!!) ![]() ![]() ![]() Wheels BRAND NEW Rota Torque 18x9 +20 all around with NEW Federal 595 tires - $800 (2) Falken RT-615k 225/45/17 (70% tread) - $150 for the pair. 4 S13 SE Alloys, tires hold air - $100 Engine SR Red Top Thermostat Housing - $25 KA24DE Starter - $40 KA24DE PS pump - $40 KA24DE Coil - $20 KA24DE IACV - $65 KA24DE AC Compressor - $40 Apexi Universal Filter - $20 Complete DOHC Power Steering Lines - $120 Drivetrain Kazama Motor mounts - $145 Megan Racing Subframe Spacers - $30 S14 Rear Subframe - $85 S13 Rear Subframe - $85 S13 Axles - $70 Suspension S14 Megan RUCA's - $90 4 Lug rear Hubs - $35 per pair S13 Stock rear knuckles with Energy Suspension bushings already pressed in - $75 I have all S13 stock suspension so let me know what you need Brakes Z32 Rear Brake Calipers, brembo rotors, carbotech brake pads and conversion brake lines (they have been rebuilt and powdercoated black, everything you need!) - $290 Stock S13 Brake calipers - $25 each Stock S13 4 Lug Rotors - $10 each Interior S13 Cluster Surround - $35 S13 Steering Wheel Adapter (nardi pattern) - $45 S13 5 Speed brake pedal - $40 S13 Black Manual Door Panels - $35 S13 Rear View Mirror - $15 S13 Center Console - $30 S13 Sun Visors - $25 S13 Gray Carpet - $75 S13 Complete Interior Wiring Harness - $130 S14 Ebrake Handle - $30 S14 Razo Shift Boot (Black with red stitching) - $30 S14 Zenki Black Face Gauge Cluster - $75 S14 Glove Box - $40 S14 Confetti rear seats - $80 GForce Blue 4pt Cam Lock Harness - $65 Exterior S13 Hatch Rear Bumper (Have 2, 1 primer, one red) $35 each S13 Popup Roof - $40 S13 Hatchback Fiberglass Rear Aero Bumper - $90 S13 Wingless Hatch - $70 S13 Driver Side Chuki Fender Extension - $30 S14 Zenki Passenger Fender - $75 S14 Passenger door - $75 S14 Sunroof Setup - $140 (I will part out the glass alone) Misc S13 Headlight trim pieces - $50 S13 Hood latch with cable - $25 S13 Upper Radiator mounting brackets - $15 S13 Windshield wiper motor - $10 S13 Gas Tank Door - $15 S14 Radiator Overflow Reservoir - $35 I have EVERYTHING so if you don't see it post/pm me. All stock parts are available. Shipping is also available on most parts. (415) 724-0675 Last edited by DJPimpFlex; 02-14-2014 at 10:51 AM.. |
![]() Join Date: Oct 2007
I'm in need of a passenger manual window track, 89-93 240sx, the plastic clips broke on mine so it's stuck, let me know
I'm in 93436 I will need it shipped Thanks
I'm in Norcal, Petaluma, North of SF. I only have DOHC KA Alternators but they actually work on SR if you swap the pulley and drill out one of the holes a little bit.
#21 | |
I don't have that unfortunately.
#24 | ||
#27 |
![]() Join Date: Jun 2003
Trader Rating: (129)
Hey I'm wondering if you have a complete body wiring harness for a hatchback. Everything from the tail lights to the fuse boxes to the headlight connectors.
#28 |
Do you still have the PS/Accessory belt tensioner parts and the AC tensioner pulley and parts that'll fit my 95? (not sure if they changed anything about them through the years) If so and they are in good shape please let me know how much shipped to 35757.
#30 | |||
