I have a 1990 300zx twin turbo and i having trouble removing the intake manifold!
I got all the bolts out of the middle and lots of other things removed as well... There is still something holding it up on the drivers side... Is there a common mistake that us retards seem to make? What am i missing? If you can help me then please do so as i really miss my car and it is just sitting, collecting dust, and losing air in the tires! ='( The left side (passenger side) is free and lifts up but somewhere on the drivers side it is tight and does not want to budge! PLEASE HELP!!! |
Check that both egr connectors on the front underside of the plenum have been removed. If this is your first plenum pull there are A LOT of hoses that have to be disconnected.
Print out this doc and go through out on the car, it may help find your problem. http://webpages.charter.net/baowuf/PlenumPull.pdf |
![]() Join Date: Aug 2005
Dude shold have hit me up Ive done countless amounts of plenum pulls what are you doing that requires the plenum pull? the only things that hold the Driverside down, is the EGR Tube, Water Lines for the Turbos and Throttle Bodies, The support braket that has the Boost Solenoids on it, and vacuum lines,
![]() Join Date: Dec 2002
agree. Wish I would have seen this sooner.
The big Biatch with the z32 mani is the egr tubes. you need a good offset ratcheting wrench, or a patient hand to remove the 2 10mm nuts from each tube. There are also many vac lines, and the brake booster hose. Not to mention the cracking prone coil pack harness and injector harness that needs to be moved out of the way.
#6 | |
![]() Join Date: Nov 2007
Trader Rating: (44)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 44 reviews
yup. or u could get luky like me and be blessed with tiny hands that make z work for me a peice of cake ![]() |
#8 | |
![]() Join Date: May 2008
Do not listen to this guy at all!!! even with his small ass hands he managed shave a hole straight thru the plenum trying to change out some injectors....... true story. Hope that customer never noticed that!!!!!!hahahah wack ass Danny !!! how u been son? |
#9 | |
Trader Rating: (44)
bitch that shit was your fault!!evrytime you came by something would break... lol and luckily we had a couple extra manifold to replace that one with! |
im new
hey guys new to the forum i got my 92 na im rebuilding a motor to be a tt and i need to know if the t and na intake manifolds are diffrent and besides pistons exhaust valves and piston rings what else do i need to make the engine swap internal wise (i know i need turbos intercooler and all the fun go fast stuff.) thanks guys it would be a big help
oh on a second not yes the na can be swapped into a tt engine by few modifications the heads crank connecting rods coil packs and mainbearings are all the same, and the na block can hold boost its jsut the top portion of the engine im starting to have questions with |
