s13 to s14???
hey guys whats going on i have an s14 zenki shell with no suspension literally a non rolling shell and was wondering if i was to buy an s13 donor car would all the suspension parts fit the s14? the s13 would have no title.
![]() Join Date: Aug 2003
Not all the suspension parts will cross over. the rear struts wont fit. the fronts will work but you will need to use s13 spindles which means you will need to use s13 lower control arms. For the rear everything else should work. I hope you at least got a rear subframe.
Drives a BRZ and is building a V6 S12 coupe. |
