Motorsports and Skilled Driving Discussion for Organized Racing and motorsports and tips and techniques at becoming a better driver. |
![]() I'm sure this is a duplicate post but i'm having trouble finding the answer i need.
I recently moved and now have a drift track 30 min away and a circuit 2ish hours away. I've been drifting my 180 for a while now, but i'd like to start getting into some grippy driving. My question is what wheel/tire sizes should I go for? I know that has been asked a million times, but i'm looking for performance, not looks. Currently, I have Enkei RPF-1's 17x9.5+18's all around. 235/40 up front and 245/45 in the rear. Front rubs at lock and I'm sure would rub under hard turning. Would i be better off getting a 16x9 or 17x9(+15?)? Can anything bigger than 235 fit under a stock front fender (rolled not pulled)? Do I even need a 235? or would a 225 be okay? I know the tire i choose plays a lot into it. Right now i'll probably get Nankangs as i cant spend $500+ for a set of tires. My suspension is pretty well upgraded. just needs to be set up to grip, not drift. |
I know a few people running square 17x9 +35 rpf1s with a 10mm spacer up front so they can rotate tires. Tires are 245/40/17. Stock body with a roll.
I have effectively the same setup waiting to be installed. |
I HAD S13 STOCK FENDERS ROLLED AND PULLED FENDER ALL AROUND 17X9+20 235/45 255/40 FIT WITH NO RUBBING WHATSOEVER BUT I WASNT AS LOW AS PEOPLE LIKE....
#5 | |
Dude the car looks amazing. Definitely looks better up like that than slammed on some homie chromies. I think I'll just get a set of wheels for track days and go from there. I wish I could fit 255's all around. |
Thank you for the kind words man. unfortunately, i had to scrap the car the more i took it apart the more North East ROT was found.
#7 | |
Kudos man, your car looks great in this pic!
Two-Tone owner#011509-Lightly Modded ![]() |
#8 | |
![]() Join Date: Apr 2007
Trader Rating: (28)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 28 reviews
Unfortunately a 16x9 will limit your tire choices if you're looking for a grippy 200TW tire. A 17x9 opens up lots of choices for 255 street tires. Try to find some takeoffs from your local autocross guys who are trying to stay at the forefront of tire grip. Why run a +15 offset? A higher offset will probably give you the clearance you need. Let me know, we can get you a great deal on a set of Enkeis. There are a few cast wheels cheaper than the RPF1s that make great budget track wheels. |
#9 | |
Tags |
autox, grip, size, tires, wheels |
